Discuss
Not washing properly, drains continuiosly
 in
Dishwasher Repair
The dishwasher does the first fill ok, washes for a few minutes, then the drain solenoid is energized for 30
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Not washing properly, drains continuiosly
  #1 (permalink)
Old 06-18-2009, 06:06 AM
Junior Member
RichardWolf is on a distinguished road
Post Not washing properly, drains continuiosly
Model Number: vsd3204g01ww   Brand: GE   Age: 5 - 10 years
The dishwasher does the first fill ok, washes for a few minutes, then the drain solenoid is energized for 30 seconds before it is de-energized. The problem is the drain valve that the solenoid pulls down stays down for the remainder of the cycle. All the other parts of the cycle happen as normal (filling, heating and power to the drain solenoid) while the drain valve stays down. Clean water never gets a chance to fill the dishwasher again after the first fill because it is continiously draining.
The drain solenoid is free to move once it is de-energized, as does the valve mechanism if there is no water pumping. I took the pump off to check for debris that may have been blocking it but found nothing. I've tried forcing the valve back up into place by pushing onto the plastic piece the solenoid pulls down when energized but only with great force is it able to move, unless you turn the power off, then it returns to the home position easily. Both springs are ok on the drain solenoid.
I'm an electrician, not a plumber, but I'm guessing it has something to do with the pressure of the pumping water that is holding the drain valve up into place because once I shut the motor off and the water stops pumping it ruturns to the normal position easily. I'm just not sure where the water is coming from, when the full cycle is completely done the bottom of the dishwasher is pumped dry, minus what is left to keep the seals moist.
Any thoughts would be appreciated, electrically I know all the components works properly, as does the timer. Thanks.
Related Models
Whirlpool VSF303PEKQ2 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool VSF303PEKQ3 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool VSF303PEKQ4 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool VSF315PEMQ1 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool VSF315PEMQ2 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool VSF315PEMQ3 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool VSF315PEMT1 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool VSF315PEMT2 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool VSF315PEMW1 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool VSF315PEMW2 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Thermador VTN1000Q HOOD VENTILATOR
Thermador VTN600Q VENTILATOR
Thermador VTR1000Q VENT SYSTEMS
Thermador VTR600R REMOTE BLOWER
Bosch VV020-000
Frigidaire VV18
Frigidaire VV201
Frigidaire VV2010
Frigidaire VV2011
Frigidaire VV2013
Frigidaire VV2014
Frigidaire VV2015
Frigidaire VV202
Frigidaire VV203
Frigidaire VV204
Frigidaire VV208
Frigidaire VV209
Bosch VV340-000
General Electric VVSR1030F0WO Washer
General Electric VVSR1030F3WO Washer
General Electric VVSR1040V0WW Washer
General Electric VVSR1040V1WW Washer
General Electric VVSR1040V2WW Washer
General Electric VVSR1040V3WW Washer
General Electric VVSR1040V4WW Washer
General Electric VVSR1070B0WW Washer
General Electric VVSR1070B3WW Washer
General Electric VVSR1070B4WW Washer
General Electric VVSR1070D0WW Washer
General Electric VVSR1070D2WW Washer
General Electric VVSR1070D5WW Washer
General Electric VVSR1070DAWW Washer
General Electric VVSR1070DCWW Washer
General Electric VVSR1070DDWW Washer
General Electric VVXR1040T2AB Washer
General Electric VVXR1040T2WB Washer
General Electric VVXR1040T3WB Washer
General Electric VVXR1040T4WB Washer
General Electric VVXR1040T5WB Washer
General Electric VVXR1040T8WB Washer
General Electric VVXR1040TAWB Washer
General Electric VVXR1040V0WW Washer
General Electric VVXR1040V1WW Washer
Frigidaire VWE5180A WESTINGHOUSE AIR CONDITIONER
General Electric VWSR3110W0AA Washer
General Electric VWSR3110W0WW Washer
General Electric VWSR3110W2AA Washer
General Electric VWSR3110W2WW Washer
General Electric VWSR4100V0AA Washer
General Electric VWSR4100V0WW Washer
General Electric VWSR4100V1AA Washer
General Electric VWSR4100V1WW Washer
General Electric VWSR4150B0WW Washer
General Electric VWSR4150B3WW Washer
General Electric VWSR4150D0WW Washer
General Electric VWSR4150D5WW Washer
General Electric VWSR4150DAWW Washer
General Electric VWSR4150DCWW Washer
General Electric VWSR4160G0WW Washer
General Electric VWXR4100T2AB Washer
General Electric VWXR4100T2WB Washer
General Electric VWXR4100T3AB Washer
General Electric VWXR4100T3WB Washer
General Electric VWXR4100T5AB Washer
General Electric VWXR4100T5WB Washer
General Electric VWXR4100T6AB Washer
General Electric VWXR4100T6WB Washer
General Electric VWXR4100T8AB Washer
General Electric VWXR4100T8WB Washer
General Electric VWXR4100TAAB Washer
General Electric VWXR4100TAWB Washer
Jenn-Air W100 WALLOVEN- S/C ELE
Jenn-Air W100-C WALLOVEN- S/C ELE
Hoover W1003-2
Whirlpool w10304543a REFRIGERATOR
Jenn-Air W104 WALLOVEN- S/C ELE
Jenn-Air W105 WALLOVEN- S/C ELE
Jenn-Air W105-C WALLOVEN- S/C ELE
Jenn-Air W106B WALLOVEN- S/C ELE
Jenn-Air W106B-C WALLOVEN- S/C ELE
Jenn-Air W106W WALLOVEN- S/C ELE
Jenn-Air W106W-C WALLOVEN- S/C ELE
Magic Chef W10AA1 WASHER-TOP LOADING
Magic Chef W10AN1 WASHER-TOP LOADING
Jenn-Air W110 WALLOVEN- S/C ELE
Jenn-Air W116 WALLOVEN- S/C ELE
Jenn-Air W120 WALLOVEN- S/C ELE
Jenn-Air W120-C WALLOVEN- S/C ELE
Jenn-Air W121 WALLOVEN- S/C ELE
Jenn-Air W121-C WALLOVEN- S/C ELE
Jenn-Air W121-E WALLOVEN- S/C ELE
Jenn-Air W122 WALLOVEN- S/C ELE
Jenn-Air W122-C WALLOVEN- S/C ELE
Jenn-Air W123 WALLOVEN- S/C ELE
Jenn-Air W123-C WALLOVEN- S/C ELE
Jenn-Air W130 WALLOVEN- S/C ELE
Jenn-Air W130-C WALLOVEN- S/C ELE
Jenn-Air W130W WALLOVEN- S/C ELE
Jenn-Air W130W-C WALLOVEN- S/C ELE
Jenn-Air W131B WALLOVEN- S/C ELE
Jenn-Air W131B-C WALLOVEN- S/C ELE
Jenn-Air W131W WALLOVEN- S/C ELE
Jenn-Air W131W-C WALLOVEN- S/C ELE
Jenn-Air W132B WALLOVEN- S/C ELE
Jenn-Air W132W WALLOVEN- S/C ELE
Jenn-Air W136 WALLOVEN- S/C ELE
Jenn-Air W136-C WALLOVEN- S/C ELE
Jenn-Air W136W WALLOVEN- S/C ELE
Jenn-Air W136W-C WALLOVEN- S/C ELE
Jenn-Air W140 WALLOVEN- S/C ELE
  #2 (permalink)
Old 06-18-2009, 06:56 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Could not find any info on this unit, please check your Model Number.
The below is for the most common type of GE dishwasher.
It sounds like you have a drain problem. Could be it empties well at the end of the cycle just because it is not trying to refill at the same time as emptying.
Have you disconnected the drain hose from the house plumbing and checked it? Often stuff will get caught at the plumbing where the drain hose fits over the male fitting into the plumbing. Could drain it into a pail to check it. Note put a towel/rag over the top of the pail and hold the hose firmly otherwise there will be water everywhere.
If you have a screen filter at the bottom back of the tub, under it will be a Piston and Nut (basically a valve). This can cause drain problems. Check it. It unscrews.
__________________
  #3 (permalink)
Old 06-19-2009, 05:31 AM
Junior Member
Default
Thanks Denman, you were bang on with this one. I filled the tub up with water, cheated the door switch and forced the solenoid into the drain mode. Water does drain but it drains to slowly. I took the valve off under the screen in the back like you said, (didn't even know that was there), the rubber seal was "dissolved" and allowing water to bypass it when the valve was closed.
Thanks again.
  #4 (permalink)
Old 06-19-2009, 05:46 AM
Senior Expert
APP Volunteer
Default
Glad it worked out for you.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
water drains while arm sprays in washing mode cowbunns Dishwasher Repair 2 11-09-2009 09:16 AM
Quiet Partner III not washing properly jensarginson Dishwasher Repair 0 06-15-2009 11:29 AM
KitchenAid dishwasher not washing properly rrcagnon Dishwasher Repair 0 10-16-2008 04:41 PM
washing machine fills and drains same time imagiggles Washer Repair 2 07-17-2008 11:36 PM
water drains before washing dishes dgk1173 Dishwasher Repair 10 06-25-2008 01:17 PM
