Discuss
BOSCH DW Does not run thru cycles
 in
Dishwasher Repair
Power is on to the unit and light comes on when starting the DW. DW will not fill and will
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » BOSCH DW Does not run thru cycles
  #1 (permalink)
Old 12-26-2007, 09:25 AM
Waterguy81 Waterguy81 is offline
Junior Member
Waterguy81 is on a distinguished road
Default BOSCH DW Does not run thru cycles
Model Number: SHU3326UC/12   Brand: Bosch   Age: 5 - 10 years
Power is on to the unit and light comes on when starting the DW. DW will not fill and will not advance thru cycles. Motor runs like usual on start up but no water inlet or advance on any of the three settings.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-27-2007, 03:33 AM
kawfeeman kawfeeman is offline
Senior Expert
APP Volunteer
kawfeeman is on a distinguished road
Default
check to see if there is any water in white basin beneath stainless steel tank ? especially to the left of the water inlet valve ?
__________________
regards
jim
  #3 (permalink)
Old 12-27-2007, 09:12 PM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
yes often these water valves leak .and all you will hear is drain pumping ,
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer Not Going Thru Most Cycles ncnicholson Washer Repair 3 11-29-2007 09:17 PM
Dryer takes two cycles to dry SlowGin Dryer Repair 3 11-09-2007 02:14 AM
Gas Dryer short cycles backdraft Dryer Repair 0 11-04-2007 07:55 AM
Cycles On When Door Is Closed GEARHEAD Dishwasher Repair 1 10-23-2007 03:50 AM
washer stops at different cycles kfoerster Washer Repair 3 09-27-2007 03:37 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
