Discuss
Dishwasher Control Panel
 in
Dishwasher Repair
Help My dishwasher is not working at all. (Kenmore Model 665-15919001) It started about a year ago with the
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher Control Panel
  #1 (permalink)
Old 12-25-2007, 09:27 PM
Andrea222 Andrea222 is offline
Junior Member
Andrea222 is on a distinguished road
Default Dishwasher Control Panel
Model Number: Model # 665 15919001   Brand: Kenmore   Age: 5 - 10 years
Help
It started about a year ago with the numbers from the "touch/control panel" not displaying properly. You couldn't see the display well enough to tell what cycle it was on. Now it has finally just "kicked the bucket."
I've been on the Sears website.. but I have no idea what part I need?
8269213 Thermal Electronic Fuse
8269205 Dual Digit Display or maybe even
8269187 Electronic Control?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-25-2007, 10:07 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Is the problem with your dishwasher only dim display or something else is wrong?
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 12-25-2007, 10:28 PM
Junior Member
Default
It used to be that only a portion of the numbers would display.
It's been broke for a couple of weeks now.. so if memory serves me correctly the last time I attempted a load of dishes it just wouldn't do anything.
  #4 (permalink)
Old 12-25-2007, 11:02 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The first thing I would do check if there is 120V from the power outlet under the sink.
Remove the bottom panel and the cover for the junction box. Check for burned wires.
Check the thermal fuse (# 6 on the control panel break down diagram).
Replace if it's open.
Check the door switches (#12 on the control panel break down diagram).
Replace if it's bad.
If nothing of the above is wrong, then replace the control board.
The display board has to be replaced in any case due to dim display.
- The part number for the display board is AP3129616
- The part number for the door switch is AP3039128
- The part number for the control board is AP3775964
- The part number for the thermal fuse is AP3178588
Good luck.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore dishwasher control panel Lori Jane Dishwasher Repair 4 01-30-2008 04:26 AM
control panel Joef Oven Repair (including Ranges and Cooktops) 0 12-20-2007 10:35 AM
Dishwasher /Remove control panel 12POINT Dishwasher Repair 1 12-07-2007 03:33 PM
Do I have a bad control panel? wenoch01 Oven Repair (including Ranges and Cooktops) 4 11-05-2007 05:51 PM
Replacing Control Panel bhandg Oven Repair (including Ranges and Cooktops) 2 07-23-2007 05:30 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
