| » Whirlpool Quiet Partner III Does Not Drain |
Model Number: GUZ2500XTPB3 Brand: Whirlpool Age: 1 - 5 years
Hello,
My Whirlpool dishwasher model Quiet Partner III (model GUZ2500XTPB3) does not drain water in normal cycles, water stays inside the machine and goes away when forced by pressing DRAIN. I checked the following: 1. Dismounted and checked PVC pipes under the sink for proper drainage - found no problem 2. Garbage disposer for proper drainage - all found working well 3. removed the drainage hose from the disposer and used a bucked - machine drained properly during regular cycles. Perhaps it is important to mention that a month ago I replaced a chopper assembly, which had gotten damaged due to broken glass. A spring, a part of the original chopper got into the grinder and never was recovered. I am curious if that could have impacted, or even damaged the pump. After replacing the chopper water pressure inside the machine returned to normal and restored relatively good operation of the machine, although my wife keeps complaining about not fully cleaned dishes. I will greatly appreciate an advice where the problem could be. Thank you Related Models |
You will need to remove dishwasher, pull the main pump, replace the pump impeller,clean out the motor screen, and also replace the check valve on the right side of the pump chopper. This check valve allows back flushing the screen when the drain pump runs.
__________________
| Display Modes | |
| Whirlpool Quiet Parnter II Locked | bigbalbossa | Dishwasher Repair | 33 | 10-22-2009 05:59 PM |
| Whirlpool Gold Quiet Partner III - takes forever and gunk after cleaning | dolemite44149 | Dishwasher Repair | 0 | 12-08-2007 03:12 PM |
| kenmore diswasher quiet guard LOUD, won't spin, keeps comming undone | ckhelga | Dishwasher Repair | 0 | 12-06-2007 12:16 PM |
| Maytag Quiet Series 300 Locked | SSaib | Dishwasher Repair | 0 | 10-23-2007 03:07 PM |
| Whirlpool dishwasher does not drain | Sdj | Dishwasher Repair | 6 | 10-09-2007 11:32 AM |
