Discuss
Dishwasher doesn't heat water?
 in
Dishwasher Repair
Heater needs replacement?? We just noted our 2 year old dishwasher isn't cleaning well, leaving particulate matter on some cups,
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher doesn't heat water?
  #1 (permalink)
Old 06-15-2009, 08:52 AM
Junior Member
fredlong is on a distinguished road
Default Dishwasher doesn't heat water?
Model Number: 665.13593k600   Brand: Kenmore   Age: 1 - 5 years
We just noted our 2 year old dishwasher isn't cleaning well, leaving particulate matter on some cups, etc. We also noticed that the water is not heating, because when we interrupt the cycle by opening the door, the "steamy blast of moist air" does not come out. The dishwasher is run on average one time a day (or slightly more).
I also just cleaned out the "steam release" panel--wow, was it caked with deposits and grit. Could this being blocked have shortened the life of the heating element? Could these deposits cause debris to be left on cups?
So, are there other things to check before buying and replacing the heating element? Also, it looks like a simple fix. Here are some instructions that I found online. Are they adequate?
  1. Shut off the main water supply in your home, which is usually in the basement. Remove the bottom rack of the dishwasher by pulling it all the way out and setting it aside.
  2. Step 2
    Unplug the dishwasher before you attempt to do any repairs. Remove the bottom access panel of the dishwasher and disconnect the wires that lead to the element. You may need a flashlight to see them. These wires are to the left inside of the panel and are white and brown on most dishwashers.
  3. Step 3
    Loosen all the brackets that hold the heating element in place by taking out the screws and gently pulling the brackets up. Lift out the old element and set aside. Place all the screws and brackets into a plastic bag so they don't get lost. You'll need these to hold down the new element.
  4. Step 4
    Place the new element in the dishwasher in the same manner that the burned-out element was set.
  5. Step 5
    Reconnect the power leads by threading them back down through to the front access panel. Wrap the wires around the electrical connectors and tighten the terminal screws. Make sure all the connections are tight.
  6. Step 6
    Replace the brackets in the dishwasher and screw them down to hold the new element in place. Jiggle the element lightly to make sure it's secure. Replace the bottom access panel.
  7. Step 7
    Turn the electricity and the water supply back on. Run the dishwasher one time without dishes or soap to make sure everything is working properly.
Ads By Google
Related Models
Kenmore 665.13601790  COMPACTOR
Kenmore 665.13603000  COMPACTORS
Kenmore 665.13604000  COMPACTORS
Kenmore 665.13605790  COMPACTOR
Kenmore 665.13608790  COMPACTOR
Kenmore 665.13612100  COMPACTORS
Kenmore 665.13613100  COMPACTORS
Kenmore 665.13614100  COMPACTORS
Kenmore 665.13619100  COMPACTORS
Kenmore 665.1386580  TRASH COMPACTOR
Kenmore 665.1386581  TRASH COMPACTOR
Kenmore 665.1386582  COMPACTOR
Kenmore 665.1388550  TRASH COMPACTOR
Kenmore 665.1388580  TRASH COMPACTOR
Kenmore 665.1388581  TRASH COMPACTOR
Kenmore 665.1388582  COMPACTOR
Kenmore 665.1396580  TRASH COMPACTOR
Kenmore 665.1396581  TRASH COMPACTOR
Kenmore 665.1396582  COMPACTOR
Kenmore 665.4098450  BUILT-IN OVEN
Kenmore 665.4098451  RANGE - ELEC
Kenmore 665.4098452  BUILT-IN OVEN
Kenmore 665.4098890  ELECTRIC BUILT-IN OVEN
Kenmore 665.4098910  ELEC. BUILT-IN OVEN
Kenmore 665.4098911  BUILT IN-ELEC. OVEN
Kenmore 665.4098912  BUILT-IN OVEN
Kenmore 665.4098913  BUILT-IN OVEN
Kenmore 665.4098914  ELEC. BUILT-IN OVEN
Kenmore 665.4098915  ELECTRIC BUILT-IN OVEN
Kenmore 665.4098990  BUILT IN WALL OVEN
Kenmore 665.4098991  BUILT-IN ELEC. OVEN
Kenmore 665.4098992  BUILT-IN OVEN
Kenmore 665.4098993  BUILT-IN OVEN
Kenmore 665.4098994  ELEC. BUILT-IN OVEN
Kenmore 665.4098995  ELECTRIC BUILT-IN OVEN
Kenmore 665.4098996  RANGE - ELEC
Kenmore 665.4098997  BUILT IN OVEN
Kenmore 665.42500  KENMORE COMPACTOR
Kenmore 665.42501  KENMORE COMPACTOR
Kenmore 665.42550  KENMORE COMPACTOR
Kenmore 665.42551  KENMORE COMPACTOR
Kenmore 665.42600  KENMORE COMPACTOR
Kenmore 665.42601  KENMORE COMPACTOR
Kenmore 665.427303-1  COMPACTOR
Kenmore 665.427303-2  COMPACTOR
Kenmore 665.427303-3  COMPACTOR
Kenmore 665.427303-4  COMPACTOR
Kenmore 665.427303-5  COMPACTOR
Kenmore 665.4428451  RANGE - ELEC
Kenmore 665.4428996  ELECTRIC DOUBLE OVEN BUILT-IN
Kenmore 665.4428997  RANGE - ELEC KENMORE
Kenmore 665.4428998  BUILT IN OVEN
Kenmore 665.4433450  BUILT-IN OVEN AND MICROWAVE
Kenmore 665.4433451  BUILT IN OVEN WITH MICROWAVE OVEN
Kenmore 665.4433452  ELEC BUILT-IN OVEN / MICROWAVE
Kenmore 665.4438890  MICRO/ELECTRIC BUILT-IN OVEN
Kenmore 665.4438913  BUILT-IN OVEN/MICRO
Kenmore 665.4438990  MICROWAVE OVEN
Kenmore 665.4438995  BUILT-IN OVEN/MICRO
Kenmore 665.4493392  MICROWAVE
Kenmore 665.4493393  ELEC BUILT-IN OVEN AND MICROWAVE
Kenmore 665.4558953  ELECTRIC COOKTOP / BUILT-IN OVEN
Kenmore 665.4558995  ELECTRIC COOKTOP
Kenmore 665.45755690  30" ELECTRIC DROP-IN RANGE
Kenmore 665.45755691  30" ELECTRIC DROP-IN RANGE
Kenmore 665.45759690  30" ELECTRIC DROP-IN RANGE
Kenmore 665.45759691  30" ELECTRIC DROP-IN RANGE
Kenmore 665.4579351  ELECTRIC RANGE
Kenmore 665.4579391  BUILT-IN RANGE
Kenmore 665.60601000  MICROWAVE/HOOD COMBO
Kenmore 665.60609000  MICROWAVE/HOOD COMBO
Kenmore 665.60612000  MICROWAVE/HOOD COMBO
Kenmore 665.60617000  MICROWAVE/HOOD COMBO
Kenmore 665.60619000  MICROWAVE/HOOD COMBO
Kenmore 665.60622000  MICROWAVE/HOOD COMBO
Kenmore 665.60629000  MICROWAVE/HOOD COMBO
Kenmore 665.60632000  MICROWAVE/HOOD COMBO
Kenmore 665.60639000  MICROWAVE/HOOD COMBO
Kenmore 665.60652000  MICROWAVE/HOOD COMBO
Kenmore 665.60654000  MICROWAVE/HOOD COMBO
Kenmore 665.60657000  MICROWAVE/HOOD COMBO
Kenmore 665.60659000  MICROWAVE/HOOD COMBO
Kenmore 665.60682000  MICROWAVE/HOOD COMBO
Kenmore 665.60689000  MICROWAVE/HOOD COMBO
Kenmore 665.61601100  MICROWAVE
Kenmore 665.61609100  MICROWAVE
Kenmore 665.61612100  MICROWAVE/HOOD COMBO
Kenmore 665.61614100  MICROWAVE/HOOD COMBO
Kenmore 665.61617100  MICROWAVE/HOOD COMBO
Kenmore 665.61619100  MICROWAVE/HOOD COMBO
Kenmore 665.61622100  MICROWAVE/HOOD COMBO
Kenmore 665.61624100  MICROWAVE/HOOD COMBO
Kenmore 665.61627100  MICROWAVE/HOOD COMBO
Kenmore 665.61629100  MICROWAVE/HOOD COMBO
Kenmore 665.61632100  MICROWAVE/HOOD COMBO
Kenmore 665.61639100  MICROWAVE/HOOD COMBO
Kenmore 665.61652100  MICROWAVE/HOOD COMBO
Kenmore 665.61652101  MICROWAVE/HOOD COMBO
Kenmore 665.61652102  MICROWAVE/HOOD COMBO
Kenmore 665.61654100  MICROWAVE/HOOD COMBO
Kenmore 665.61654101  MICROWAVE/HOOD COMBO
Kenmore 665.7042700  SEARS COMPACTOR
Kenmore 665.7042701  KENMORE COMPACTOR
Kenmore 665.7242600  SEARS KENMORE COMPACTOR
Kenmore 665.7242601  SEARS COMPACTOR
Kenmore 665.7242602  KENMORE COMPACTOR
Kenmore 665.7242700  KENMORE COMPACTOR
Kenmore 665.7242701  SEARS COMPACTOR
Kenmore 665.7242702  KENMORE COMPACTOR
Kenmore 665.7242703  KENMORE COMPACTOR
Kenmore 665.7242705  KENMORE COMPACTOR
Kenmore 665.7242706  KENMORE COMPACTOR
Kenmore 665.7242707  KENMORE COMPACTOR
Kenmore 665.7242751  SEARS COMPACTOR
Kenmore 665.7342200  KENMORE COMPACTOR
Kenmore 665.7342201  KENMORE COMPACTOR
Kenmore 665.7342202  KENMORE COMPACTOR
Kenmore 665.7342203  KENMORE COMPACTOR
Kenmore 665.7342204  KENMORE COMPACTOR
Kenmore 665.7342300  KENMORE COMPACTOR
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher will not heat water underachiever Dishwasher Repair 3 01-18-2010 02:27 PM
Dishwasher does not heat water - cycles too long shishilla2002@yahoo.com Dishwasher Repair 0 08-10-2009 11:13 AM
Haier dishwasher- no heat magomeara Dishwasher Repair 0 02-05-2009 07:26 AM
Will not heat water wwilson Dishwasher Repair 1 01-15-2009 02:44 AM
Dishwasher water won't heat kdtokolish Dishwasher Repair 1 02-09-2008 10:46 AM
