Discuss
Bosch Dishwasher won't drain
 in
Dishwasher Repair
My Bosch dishwasher won't drain water from the bottom. I have cleaned both filters and I know the outflow
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch Dishwasher won't drain
  #1 (permalink)
Old 12-24-2007, 09:31 PM
reisman reisman is offline
Junior Member
reisman is on a distinguished road
Default Bosch Dishwasher won't drain
Model Number: SHV46C03UC   Brand: Bosch   Age: 1 - 5 years
My Bosch dishwasher won't drain water from the bottom. I have cleaned both filters and I know the outflow hose going to the blue assembly underneath is unobstructed. The hose going back to the garbage disposal is also unclogged, flexible and open, at least the last 2 feet of it. There is no obstruction in the opening into the garbage disposal. Please advise what I should do. I am very handy, and this is a horrible time to have this happen, as I have house guests coming in two days, and I need to get this working again.
Thanks, reisman
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-25-2007, 02:45 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Hit drain button, put end of drain hose in a bucket to see if anything comes out, may be something in there. If nothing, maybe the drain pump is bad or no voltage to it. Open up control panel and per. the schematic, check the voltage going to the motor. If no voltage, you probably have a bad control module, if voltage, you have a bad/clogged pump.
__________________
  #3 (permalink)
Old 12-25-2007, 06:41 AM
Junior Member
Default Further questions on Bosch noted above
Thank you for the response. Can you tell me where the drain button is on this Bosch. Is your answer specific for this Bosch? The relatively short hose exiting the bottom of the tub, just below the filters goes into what I believe to be the pump. It is plastic and blue in color, down at the bottom. Does the unit need to be removed from the cabinetry to get to this, or is there another way to get to that pump without having to unbracket the whole dishwasher? Any specifics you can give me will be most appreciated. The voltages will also help. Thanks, reisman
  #4 (permalink)
Old 12-25-2007, 08:34 PM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
press on off power switch to on position. press+hold regularwash+powerscrub together
__________________
  #5 (permalink)
Old 12-27-2007, 03:50 AM
kawfeeman kawfeeman is offline
Senior Expert
APP Volunteer
kawfeeman is on a distinguished road
Default
can you hear the drain pump running ? most often best to remove d/w and take off left side panel to see what is restricting water flow... i usually see either food stuffs caught in diverter on left side of d/w or a kinked drain hose from installer ( in a hurry .. ) ..
__________________
regards
jim
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacing Drain Hose on Bosch Dishwasher Lorenzo Dishwasher Repair 3 10-02-2008 12:31 PM
Bosch drain pumps does not turn off? dallymemally Dishwasher Repair 2 10-26-2007 05:09 PM
Bosch dishwasher sherryg Dishwasher Repair 0 10-08-2007 11:46 AM
Bosch drain pump replacement Tom4852 Dishwasher Repair 3 10-03-2007 06:04 PM
Bosch Dishwasher Won't Drain jshoe01 Dishwasher Repair 2 09-06-2007 11:27 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
