Discuss
Kenmore doesn't clean-"Clean " Flashning Seven times
 in
Dishwasher Repair
I have a Kenmore dishwasher that appears to go through its cleaning cycle however there is soap residue left in
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Kenmore doesn't clean-"Clean " Flashning Seven times
  #1 (permalink)
Old 12-24-2007, 10:43 AM
Junior Member
demark is on a distinguished road
Default Kenmore doesn't clean-"Clean " Flashning Seven times
Model Number: 165-14200   Brand: Sears   Age: 1 - 5 years
I have a Kenmore dishwasher that appears to go through its cleaning cycle however there is soap residue left in dispenser and dishes are not clean. "Clean" light flashes 7 times--does that refer to a trouble code?
Thanks-Merry Christmas !!
Ads By Google
Related Models
Whirlpool 1653W0A
Whirlpool 1653W1A
Whirlpool 1653W2A
Whirlpool 1653^0A
Whirlpool 1653^1A
Whirlpool 1653^2A
Hoover 168691 Electrolux/refrigerator
Magic Chef 16RA-3B Rv Range - Gas
Magic Chef 16RA-3B-49 Rv Range - Gas
Magic Chef 16RA-3BK Rv Range - Gas
Magic Chef 16RA-3BKZ Rv Range - Gas
Magic Chef 16RA-3BT Rv Range - Gas
Magic Chef 16RA-3BT49 Rv Range - Gas
Magic Chef 16RA-3BTZ Rv Range - Gas
Magic Chef 16RA-3BZ Rv Range - Gas
Magic Chef 16RA-4 Rv Range - Gas
Magic Chef 16RA-4K Rv Range - Gas
Magic Chef 16RA-4KZ Rv Range - Gas
Magic Chef 16RA-4T Rv Range - Gas
Magic Chef 16RA-4TZ Rv Range - Gas
Magic Chef 16RA-4Z Rv Range - Gas
Magic Chef 16RB-3B Rv Range - Gas
Magic Chef 16RB-3BK
Magic Chef 16RB-3BKZ
Magic Chef 16RB-3BT Rv Range - Gas
Magic Chef 16RB-3BTZ Rv Range - Gas
Magic Chef 16RB-3BZ Rv Range - Gas
Magic Chef 16RB-4 Rv Range - Gas
Magic Chef 16RB-4K
Magic Chef 16RB-4KZ Rv Range - Gas
Magic Chef 16RB-4T
Magic Chef 16RB-4TZ Rv Range - Gas
Magic Chef 16RB-4Z Rv Range - Gas
Magic Chef 16RS-4 Rv Range - Gas
Magic Chef 16RS-4K Rv Range - Gas
Magic Chef 16RS-4KZ
Magic Chef 16RS-4T Rv Range - Gas
Magic Chef 16RS-4TZ
Magic Chef 16RS-4Z Rv Range - Gas
Magic Chef 16RW-3B Rv Range - Gas
Magic Chef 16RW-3B-49 Rv Range - Gas
Magic Chef 16RW-3BK Rv Range - Gas
Magic Chef 16RW-3BKZ Rv Range - Gas
Magic Chef 16RW-3BT Rv Range - Gas
Magic Chef 16RW-3BT49 Rv Range - Gas
Magic Chef 16RW-3BTZ Rv Range - Gas
Magic Chef 16RW-4 Rv Range - Gas
Magic Chef 16RW-4K Rv Range - Gas
Magic Chef 16RW-4KZ Rv Range - Gas
Magic Chef 16RW-4T Rv Range - Gas
Magic Chef 16RW-4TZ Rv Range - Gas
Magic Chef 16RW-4Z Rv Range - Gas
Magic Chef 16TA-3B-49 Rv Range - Gas
Magic Chef 16TA-3BK49 Rv Range - Gas
Magic Chef 16TA-3BZ Rv Range - Gas
Magic Chef 16TA-4Z Rv Range - Gas
Magic Chef 16TB-3B Rv Range - Gas
Magic Chef 16TB-3BK Rv Range - Gas
Magic Chef 16TB-3BZ Rv Range - Gas
Magic Chef 16TB-4 Rv Range - Gas
Magic Chef 16TW-3B Rv Range - Gas
Magic Chef 16TW-3B-49 Rv Range - Gas
Magic Chef 16TW-3BK Rv Range - Gas
Magic Chef 16TW-3BK49 Rv Range - Gas
Magic Chef 16TW-3BKE Rv Range - Gas
Magic Chef 16TW-3BKZ Rv Range - Gas
Magic Chef 16TW-3BZ Rv Range - Gas
Magic Chef 16TW-4KZ Rv Range - Gas
Thermador 1701
Amana 1708.000 Mwave - Family Size (60 Hz)
Amana 1708.001 Mwave - Family Size (60 Hz)
Amana 1709.000 Mwave - Family Size (60 Hz)
Amana 1709.001 Mwave - Family Size (60 Hz)
Amana 1718.000 Mwave - Family Size (60 Hz)
Amana 1718.001 Mwave - Family Size (60 Hz)
Amana 1720.000 Mwave - Family Size (60 Hz)
Amana 1736.000 Mwave - Family Size (60 Hz)
Amana 1736.001 Mwave - Family Size (60 Hz)
Amana 1739.000 Mwave - Family Size (60 Hz)
Amana 1739.001 Mwave - Family Size (60 Hz)
Whirlpool 1743W0A
Whirlpool 1745W0A
Whirlpool 1745^0A
Amana 1750.000 Mwave - Family Size (60 Hz)
Amana 1752.000 Mwave - Family Size (60 Hz)
Amana 1752.001 Mwave - Family Size (60 Hz)
Whirlpool 1765W0A
Whirlpool 1765^0A
Amana 1780.000 Mwave - Family Size (60 Hz)
Amana 18 Freezer - Vertical
Whirlpool 1821W06
Whirlpool 1821^06
Whirlpool 1833W0A
Whirlpool 1833^0A
Whirlpool 1835W0A
Whirlpool 1835W1A
Whirlpool 1835W2A
Whirlpool 1835^0A
Whirlpool 1835^1A
Whirlpool 1835^2A
Whirlpool 1835^3A
Whirlpool 1838W46
Whirlpool 1838W56
Whirlpool 1838W66
Whirlpool 1838^46
Whirlpool 1838^56
Whirlpool 1838^66
Amana 1870.000 Mwave - Family Size (60 Hz)
Whirlpool 1872W0A
Whirlpool 1872W1A
Whirlpool 1873W0A
Whirlpool 1873W1A
Whirlpool 1873^0A
Whirlpool 1873^1A
Whirlpool 1878W26
Whirlpool 1878W36
Whirlpool 1878W46
Whirlpool 1878^26
Whirlpool 1878^36
Whirlpool 1878^46
  #2 (permalink)
Old 12-24-2007, 11:10 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The "Clean" light, flashing 7 times means a problem in the heating circuit.
Reset the control as described in the tech's sheets (located in a pouch behind the bottom panel).
If it'll happen again, check the heating element and the high limit thermostat.
The model number you posted is incomplete.
Happy Holidays!
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 12-25-2007, 01:51 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
Your hot water may be too cold, just increase temperature.
Open door, within 3 seconds hit high temp. scrub,energy saver dry, then repeat (if no such buttons press similar ones} Close door and press cancel. Good luck,Merry Christmas.
__________________
  #4 (permalink)
Old 12-27-2007, 02:17 PM
Junior Member
Neal is on a distinguished road
Default
I have the same problem with my Kenmore. How do you reset the dishwasher as stated in the early post. There's nothing in my tech sheet.
Thanks.
  #5 (permalink)
Old 12-27-2007, 02:47 PM
Senior Expert
APP Volunteer
Default
Just follow the directions for Demark above
__________________
  #6 (permalink)
Old 12-28-2007, 02:52 AM
Junior Member
Default
I was able to reset the flashing green light. There was no error code shown afterwards. Then I ran the normal wash cycle. Took a few minutes
to start. On the screen started at 55, went down to 48 (?) then dropped to 2. Finished out the cycle. Afterwards the flashing green light. I could do the sequence all over again. Neal
  #7 (permalink)
Old 12-28-2007, 04:28 AM
Senior Expert
APP Volunteer
Default
Check your service sheet. The dishwasher is sensing a bad heater. Check the heater and heater thermostat.
__________________
  #8 (permalink)
Old 12-28-2007, 04:53 AM
Junior Member
Default
I'm at work right now, How do I check those items? I'll check them later this evning. Thanks for your help.
  #9 (permalink)
Old 12-28-2007, 06:02 AM
Senior Expert
APP Volunteer
Default
Crunch your model # in this site to get assembly info.
__________________
  #10 (permalink)
Old 12-28-2007, 05:05 PM
Junior Member
Default
Richappy, Where on this site do you find that info? First time user, Sorry.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
"CLEAN" cycle light always flashing Tadek Dishwasher Repair 11 01-04-2012 12:29 PM
blinking green light next to "clean" smokie Dishwasher Repair 1 10-23-2009 06:16 AM
no spin during "ultra clean" cycles krapp@trust-landmark.com Washer Repair 2 12-29-2008 02:40 PM
Blinking "Clean" light? DAVIDW Dishwasher Repair 0 07-06-2008 07:23 AM
Flashing "Clean" Light Fiver Lee Dishwasher Repair 0 03-06-2008 10:57 AM
