Discuss
Kenmore doesn't clean-"Clean " Flashning Seven times
 in
Dishwasher Repair
No I didn't. I check everything at the control board, The back off the connector. Ads By Google
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Kenmore doesn't clean-"Clean " Flashning Seven times
  #41 (permalink)
Old 01-09-2008, 02:00 AM
Junior Member
Neal is on a distinguished road
Default
Ads By Google
  #42 (permalink)
Old 01-10-2008, 02:44 AM
Junior Member
Default
Thanks you everyones input. I'm not going to fix it. Tired of fooling with it after 3 weeks. I'm going to replace the unit with another one. Thanks
  #43 (permalink)
Old 01-27-2008, 07:55 PM
Junior Member
Tyro is on a distinguished road
Exclamation Different model, same seven blinks
I have a Kenmore model 66517019400. I assume the seven "clean" blinks mean the same thing on my model as the others. I tried pushing the buttons that more closely matched the one suggested earlier, but without luck. What buttons should I push on my model? Thanks.
  #44 (permalink)
Old 01-28-2008, 03:41 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
You have to reset the computer. Pull your service sheet, procedure should be in there. If not do the following.
Open door and within 3 seconds, press the hi temp. scrub, then energy saver buttons, then repeat. Close and latch door and hit the cancel button, should reset.
The cause of this is low water temperature, or a bad heater circuit.
__________________
  #45 (permalink)
Old 03-10-2008, 01:17 PM
Junior Member
hpmem is on a distinguished road
Default
I have the Model 665.1602 I reset the CLEAN flashing light by using the sugestion this forum it said to:
Try Pressing:
Normal Wash - HeatedDry -Normal Wash – HeatedDry- Normal Wash – HeatedDry- Normal Wash - HeatedDry[/font] . all the lights should come on. then after a little bit. keep pressing start till disher washer gets back to normal shut down. what happen your water was to cold going into the disherwasher one time taking to long to warm up. the dishwaher went into a fault mode. the light blinks 7 times because there was a fault with your heater circuit. this should take care of it.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
"CLEAN" cycle light always flashing Tadek Dishwasher Repair 11 01-04-2012 12:29 PM
blinking green light next to "clean" smokie Dishwasher Repair 1 10-23-2009 06:16 AM
no spin during "ultra clean" cycles krapp@trust-landmark.com Washer Repair 2 12-29-2008 02:40 PM
Blinking "Clean" light? DAVIDW Dishwasher Repair 0 07-06-2008 07:23 AM
Flashing "Clean" Light Fiver Lee Dishwasher Repair 0 03-06-2008 10:57 AM
