Discuss
Kenmore doesn't clean-"Clean " Flashning Seven times
 in
Dishwasher Repair
Post the model number on the forum. Gene.
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Kenmore doesn't clean-"Clean " Flashning Seven times
  #11 (permalink)
Old 12-28-2007, 06:39 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
__________________
Professional appliance repair in Los Angeles, California.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #12 (permalink)
Old 12-29-2007, 04:39 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Post your model # and click on it!
__________________
  #13 (permalink)
Old 12-29-2007, 08:19 AM
Neal Neal is offline
Junior Member
Neal is on a distinguished road
Default
66516959000
I took the themostat off. I checked it with my multimeter. I get 0 ohms. Does that mean its opened or closed? And is that correct? Or is this the faulty part?
  #14 (permalink)
Old 12-29-2007, 10:56 AM
Senior Expert
APP Volunteer
Default
Heater thermostat is supposed to be closed at room temperature. Check your heater.
__________________
  #15 (permalink)
Old 12-29-2007, 11:48 AM
Junior Member
Default
I got a reading of 0 ohms
  #16 (permalink)
Old 12-29-2007, 12:05 PM
joyfulljoy joyfulljoy is offline
Junior Member
joyfulljoy is on a distinguished road
Default Clean light flashing 7 times
I have the same problem with my clean light flashing 7 times. I have no tech sheets and no scrub or energy saver buttons to push. the model number is 66516032401. Any suggestions? Thanks!
  #17 (permalink)
Old 12-29-2007, 03:42 PM
Senior Expert
APP Volunteer
Default
Just press similar buttons, usually side by side.
__________________
  #18 (permalink)
Old 12-30-2007, 09:45 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Neal
Did you remove at least one wire from the heater before testing the resistance?
If not - you got a wrong reading.
If yes, then the heater is bad and has to be replaced.
In order to find the right part number for the heater I need to know if the tub is made of plastic or stainless still.
Happy New year!
__________________
  #19 (permalink)
Old 12-31-2007, 07:32 AM
Junior Member
Default
No I didn't Gene. I will do that and let you know. Thanks
  #20 (permalink)
Old 12-31-2007, 08:48 AM
Junior Member
Default
12.8 ohms with both leads off of heater
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
"CLEAN" cycle light always flashing Tadek Dishwasher Repair 9 07-22-2008 06:01 PM
Kenmore (Whirlpool) washer "bang" noise when spinning dadasmatta Washer Repair 2 12-22-2007 08:34 PM
Older Kenmore washer appears "dead"! Cappy Washer Repair 0 10-27-2007 08:18 PM
Starts cycle, gets "stuck" with h2o in bottom, timer is still heard-lights on too. julialovesjohn Dishwasher Repair 1 10-03-2007 08:16 PM
Oven oesn't bake/heat and displays a "FS" error message jnymdnyt Oven Repair (including Ranges and Cooktops) 5 08-06-2007 07:36 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
