Water will not drain in between or at the end of cycles. :( I would need to press "cancel/drain" several times to clear the water. :mad: I thought there may have been a clog in the drain-pump but I did not find one. :confused: The pump seems to "spin" (viewed directly) but It doe not seem to clear the water. Does the drain pump commonly go bad? :eek: Is there another valve I should be checking? Could the sensor at the bottom of the basin be the problem?
(This problem occured first) Water would not spray out of the upper arms and I saw soap residue remaining in the cup after the cycle was completed. I located the chopper assembly and fouund it to be "clogged". I would clear it, pressure would be great again but in time I would need to repeat the process. How can I tell if the chopper is broken? Should the metal blades spin separately from the metal cap? Did this condition contribute to my primary posting
Thanks Alan
