Discuss
top sprayer arm doesn't work
 in
Dishwasher Repair
Dishwasher top sprayer arm doesn't get water. It moves fine and doesn't seem to be any blockage. Any
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » top sprayer arm doesn't work
  #1 (permalink)
Old 12-23-2007, 11:42 AM
lGrasberger lGrasberger is offline
Junior Member
lGrasberger is on a distinguished road
Default top sprayer arm doesn't work
Model Number: 665.16039403   Brand: Kenmore   Age: 1 - 5 years
Dishwasher top sprayer arm doesn't get water. It moves fine and doesn't seem to be any blockage. Any ideas
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-23-2007, 11:55 AM
TechnicianBrian's Avatar
TechnicianBrian TechnicianBrian is offline
Senior Expert
APP Volunteer
TechnicianBrian is on a distinguished road
Default
Your pump has a chopper assembly that can become clogged when it breaks, or blocked with debris. If the chopper is broken you will need a new one. Here is a video that shows how to access the pump.
__________________
TechnicianBrian
Appliance Repair Blog
  #3 (permalink)
Old 12-25-2007, 03:07 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
If your chopper is clogged, order a new one and the check valve next to it in the bottom of the housing. This check valve back flushes the screen while pumping out. When replacing the chopper, make sure it turns when the pump runs. To do this, turn water off, keep cover off the pump housing and run dishwasher. If chopper doesn't turn, you need a new pump impeller.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher won't wash on top rack-no blockage noted of sprayer arm lGrasberger Dishwasher Repair 2 12-25-2007 03:47 AM
want work pccurtis Dishwasher Repair 0 11-21-2007 02:07 PM
second level sprayer denpet Dishwasher Repair 0 10-25-2007 11:24 AM
Top sprayer not working buh Dishwasher Repair 0 10-24-2007 07:58 PM
$200 and still don't work Rakar Dishwasher Repair 2 07-27-2007 10:14 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
