I hope you can help.
Have a couple of inches of water at the bottom of the dishwasher.
Tried garbage disposal - it seems OK.
Run a couple of different cycles, I hear it is working. In the end, approx. the same amount of water still at the bottom.
Run a wash cycle, hit reset - didn't drain
Got most of the water out (using a cup) - 1/4 inch left. Run Rinse - heard water coming-in for 10-15 seconds, then it stopped - same 1/4 inch of water.
Run a wash cycle - water was running fine. Interrupted it with Reset 10 minutes later - approx. 2 inches of water again.
Any help? I am somewhat intimidated with opening the panel undernease of the dishwasher, but seems like this is where the problem and solution might be.
Thanks! Ik
