Discuss
Maytag washer - replace belts or pump?
 in
Dishwasher Repair
The washer stopped draining water from the tub in the final spin cycle. I tried repositioning the timer switch to
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Maytag washer - replace belts or pump?
  #1 (permalink)
Old 11-28-2011, 02:07 PM
Junior Member
mzpatti is on a distinguished road
Question Maytag washer - replace belts or pump?
Model Number: A883   Brand: Maytag   Age: More than 10 years
The washer stopped draining water from the tub in the final spin cycle. I tried repositioning the timer switch to "spin" in perma press, but same results. Checked for obstructions in water drain from tub to pump and from pump to drain. No clogs.
I opened front of washer cabinet to check to see if pump pulley is spinning when washer is in "spin" cycle. Pump pulley is stationary while machine is in "spin". Pump belt is very loose and not moving, while motor and drive belt are moving.
So, is it the pump pulley/pump, or pump belt? Doing the pump belt adjustment, there is no space between the inside surfaces of the pump belt.
Ads By Google
Related Models
Maytag A883 Washer - Top Loading
Maytag A883T Washer - Top Loading
Maytag A884 Washer - Top Loading
Maytag A8840 Washer - Top Loading
Maytag A884T Washer - Top Loading
Admiral A88FK-1 Surface Unit - Ele
Admiral A88FK-2-R Surface Unit - Ele
Admiral A88FK-6-R Surface Unit - Ele
Admiral A88FN-2-R Surface Unit - Ele
Admiral A88FN-2R Surface Unit - Ele
Admiral A88LK-6-R Surface Unit - Ele
Admiral A88LN-6-R Surface Unit - Ele
Admiral A89L-4-R Surface Unit - Ele
Frigidaire A8LECUD2 Frg(v20) / Room Air Conditioner
Frigidaire A8MECC2 Frg(v15) / Room Air Conditioner
Frigidaire A8MECD2 Frg(v21) / Room Air Conditioner
Frigidaire A8MECUC2 Frg(v16) / Room Air Conditioner
Frigidaire A8MECUC3 Frg(v17) / Room Air Conditioner
Frigidaire A8MECUSC2 Frg(v6) / Room Air Conditioner
Frigidaire A8MECUSC3 Frg(v7) / Room Air Conditioner
Maytag A900 Washer - Top Loading
Maytag A900S Washer - Top Loading
Maytag A902 Washer - Top Loading
Maytag A906 Washer - Top Loading
Jenn-Air A910 Misc / Accessory
Admiral A9122VPV Walloven - Std Gas
Maytag A9200 Washer - Top Loading
Admiral A9211XPB Walloven - Cont Clean Gas
Admiral A9222VPV Walloven - Cont Clean Gas
Admiral A9222XPB Walloven - Cont Clean Gas
Maytag A9300 Washer - Top Loading
Maytag A9400 Washer - Top Loading
Maytag A9400S Washer - Top Loading
Maytag A9400W Washer - Top Loading
Admiral A9475VRV Walloven - S/c Gas
Admiral A9475XRB Walloven - S/c Gas
Admiral A9495VRV Range - S/c Mwave Gas
Admiral A9495XRB Range - S/c Mwave Gas
Maytag A9600 Washer - Top Loading
Maytag A9700 Washer - Top Loading
Maytag A9700S Washer - Top Loading
Maytag A9700W Washer - Top Loading
Maytag A9800 Washer - Top Loading
Admiral A9814XPB Walloven - S/c Ele
Admiral A9845VPV Walloven - S/c Ele
Admiral A9845XPB Walloven - S/c Ele
Admiral A9854VPV Walloven - S/c Ele
Admiral A9854XPB Walloven - S/c Ele
Admiral A9875VRV Walloven - S/c Ele
Admiral A9875XRB Walloven - S/c Ele
Admiral A9895VRV Walloven - S/c Mwave Ele
Admiral A9895XRB Walloven - S/c Mwave Ele
Maytag A9900 Washer - Top Loading
General Electric A9B568DAALSA Zoneline
General Electric A9B568EPASSA Zoneline
General Electric A9B678DAALWA Zoneline
General Electric A9B678EPASWA Zoneline
General Electric A9B688DAALW1 Zoneline
General Electric A9B688DAASW1 Zoneline
General Electric A9B688DEALW1 Zoneline
General Electric A9B688DEASW1 Zoneline
General Electric A9B688DJALW1 Zoneline
General Electric A9B688DJASW1 Zoneline
General Electric A9B688EPASW1 Zoneline
Maytag AA108 Washer - Top Loading
Maytag AA208 Washer - Top Loading
Maytag AA308 Washer - Top Loading
Maytag AA308S Washer - Top Loading
Amana AA3110 Washer - Top Loading
Amana AA3111 Washer - Top Loading
Amana AA3210 Washer - Top Loading
Amana AA3410 Washer - Top Loading
Maytag AA408 Washer - Top Loading
Maytag AA408S Washer - Top Loading
Amana AA4110 Washer - Top Loading
Amana AA4111 Washer - Top Loading
Amana AA4210 Washer - Top Loading
Amana AA4211 Washer - Top Loading
Amana AA4410 Washer - Top Loading
Amana AA4411 Washer - Top Loading
General Electric AA508AAS1 Room air conditioner
Amana AA5121 Washer - Top Loading
Amana AA5220 Washer - Top Loading
Amana AA5221 Washer - Top Loading
Amana AA5222 Washer - Top Loading
Amana AA5420 Washer - Top Loading
Amana AA5421 Washer - Top Loading
Maytag AA608 Washer - Top Loading
Maytag AA608S Washer - Top Loading
Amana AA6121 Washer - Top Loading
Amana AA6221 Washer - Top Loading
Amana AA6421 Washer - Top Loading
General Electric AA708AMS1 Room air conditioner
Amana AA7131 Washer - Top Loading
Amana AA7231 Washer - Top Loading
Maytag AA806 Washer - Top Loading
Maytag AA806S Washer - Top Loading
Amana AA8431 Washer - Top Loading
Amana AA9131 Washer - Top Loading
Amana AA9231 Washer - Top Loading
Amana AA9431 Washer - Top Loading
Amana AAC051FRA Room Air Conditioner
Amana AAC051FRB  Room Air Conditioner
Amana AAC051STA  Room Air Conditioner
Amana AAC061STA Room Air Conditioner
Amana AAC071FRA Room Air Conditioner
Amana AAC081SRA Room Air Conditioner
Amana AAC081SRB  Room Air Conditioner
Amana AAC081STA Room Air Conditioner
Amana AAC101SRA Room Air Conditioner
Amana AAC101STA Room Air Conditioner
Amana AAC121SRA Room Air Conditioner
Amana AAC121STA  Room Air Conditioner
Amana AAC141SRA Room Air Conditioner
Amana AAC182SRA Room Air Conditioner
Amana AAC182STA Room Air Conditioner
Amana AAC202SRA Room Air Conditioner
Amana AAC242SRA  Room Air Conditioner
Admiral AAV1000AWW Washer - Top Loading
Admiral AAV1100AWW Washer - Top Loading
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How do I replace a drain pump on a bosch washer? Arnold R. Washer Repair 0 08-27-2011 02:12 PM
Installation instructions for Drive and Pump Belts avalon321 Washer Repair 1 02-13-2011 08:02 AM
I Need To Replace The Pump On My Maytag Dishwasher KAREN1S Dishwasher Repair 1 02-06-2010 01:39 PM
How to replace washer pump gricodrywall Washer Repair 2 12-30-2009 04:03 AM
How to replace washer pump gricodrywall Washer Repair 0 12-29-2009 03:51 AM
