| » DW won't fill, slight leak underneath |
Model Number: SHU3305UC Brand: Bosch Age: 5 - 10 years
I have a Bosch SHU3305 (FD 8207) DW that will run forever without delivering water. I cleaned the screens and removed the cover on the prop and cleaned the backfill valve. There is a very slow drip underneath the unit (about center-left). Any idea what might need replacing?
Thanks! TG Ads By Google Related Models |
Thanks TommyH.
Problem started with extra water in bottom of tub. So I did the cleaning. Then I poured a gallon of water in the tub to "prime it" and when the DW first starts up it drains that water out... so I'm guessing the pump is working and the drain line is clear. But I don't hear any audible changes, so yes, maybe its the pump not shutting off. When left on for a while,the DW will shut off and start up again. When I ran the "test" it registered "Regular Wash = water filling fault (over or under filling)". Any ideas? Thanks so much! T Grenchik |
HI TOMMY .I bought Bosch product and i had some problems as well.You can get all the help required for fixing or reparing these products from fixya.com.Hope you might get solution.
____________________________ Power Supplies Last edited by EmilyWatson : 11-30-2011 at 11:10 PM. |
| Display Modes | |
| water fill leak | harry k | Refrigerator & Freezer Repair | 0 | 03-18-2011 06:37 PM |
| Leak At Funnel Fill | tnowak | Dishwasher Repair | 1 | 09-10-2010 04:03 AM |
| Kenmore dishwasher leak underneath | moorek | Dishwasher Repair | 9 | 03-29-2010 01:52 PM |
| water leak at fill | jimhagner | Washer Repair | 1 | 12-28-2009 10:57 AM |
| Leak during fill cycle | myslyn | Washer Repair | 3 | 02-09-2009 01:39 PM |
