Discuss
Dishwasher bottom leaking slowly from sump
 in
Dishwasher Repair
I fixed something in my dishwasher for the first time (broken spray arm). When I put it back, I was
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher bottom leaking slowly from sump
  #1 (permalink)
Old 12-21-2007, 10:17 PM
gabhroo gabhroo is offline
Junior Member
gabhroo is on a distinguished road
Default Dishwasher bottom leaking slowly from sump
Model Number: GSD400W-56AD   Brand: GE   Age: More than 10 years
I fixed something in my dishwasher for the first time (broken spray arm). When I put it back, I was trying to make sure that nothing was leaking. I noticed that there was indeed a small leak, but from a spot that I did not touch.
The leak was from the portion where sump is connected to the bottom of the tub. I tried fastening the sump mounting clamp a bit more, but that actually increased the pace of leaking. Loosening it a bit reduced the leakage again (around 3 drops a minute).
I am not sure if this leakage was always there, or has it been caused by me jostling the machine around a bit.
It seems it is leaking around the rim where it connects to the tub.
Any suggestions? I have read something about the silicone adhesive on the net. Is that something to try (pasting it all over the border)? Where do I get it? Any other suggestions?
Thanks.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Crosley Cw8000w Leaking on rinse cycle from bottom of the tub? roller2 Washer Repair 2 01-12-2008 10:10 AM
Dishwasher leaking from bottom of front door kipper Dishwasher Repair 1 11-14-2007 04:23 PM
dishwasher leaking on the bottom gerald Dishwasher Repair 1 10-05-2007 04:52 AM
dishwasher leaking at bottom of door skinnybeak Dishwasher Repair 0 09-24-2007 06:22 PM
Maytag Washer Bottom of tub leaking at seal David S Washer Repair 4 08-11-2007 12:16 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
