My Kenmore will not turn on, but the dual digit numeric display flashes one horzintal LED unit. I have replaced everything including the power module, the thermo fuse and the heating element, but nothing helps.
I have confirmed the door latch is working properly, but still not joy in solving the problem. Then by accident I was shining my highpwered hald held flashlight on the door when all of a sudden the pannel lit up and the washer started to empty water. If I moved the light off the numeric digit display, the machine stopped and the single LED line started to blink again. What a crazy thing. I have talked to experts and they can not explain what is happening.
Can you? Thanks, Jimwhart
