Discuss
Bosch Circulation pump, low flow but nothing visably wrong.
 in
Dishwasher Repair
Hi, I have a Bosch 8805 that has low water flow. It happened suddenly one day, the machine made a
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch Circulation pump, low flow but nothing visably wrong.
  #1 (permalink)
Old 06-07-2009, 03:08 PM
Junior Member
Terry O'Brien is on a distinguished road
Default Bosch Circulation pump, low flow but nothing visably wrong.
Model Number: SHU8805UC/12   Brand: Bosch   Age: 5 - 10 years
I have a Bosch 8805 that has low water flow. It happened suddenly one day, the machine made a slow whirring sound when it went into the wash cycle. Actually, it sounded just like a slow gear motor -- if that means anything to you.
Anyway, low water flow didn't have sufficient pressure to move the arms.
I felt inside the circulation impeller and was able to rotate the impeller. So the motor is not seized. When I was feeling from the sump to the circulation impeller, I noticed a bit of something black that I thought was debris. When I went to pick it up, it smeared like black grease. I immediately assumed that the seals on the motor bearings were gone.
I have since removed the circulation pump, and aside from some deterioration of the plastic on the chamber that forms the exit venturi, everything looks OK (I assume that the plastic impeller is supposed to just snap into the holes on the rubber impeller base on the motor). It would appear that my black "grease" came from the small O-ring inside the short pipe that attaches the impeller chamber to the sump.
Now that I see that the grease didn't come from the motor, I am less secure in my assumption that the motor is shot.
Before I order a new circulation motor assembly, I wanted to ask if anything else could cause the motor to run slowly?
Would a bad capacitor affect the running of the motor?
Any suggestions of other stuff to check that doesn't require putting the thing back together?
One other unrelated thing. When I was pulling the base off the machine, I didn't record where the air hose was attached to the base. I assume that the air hose that starts on the right side of the machine (as you face it from the front) isn't attached to anything. Right? It just terminates in a groove at the back of the base?
Ads By Google
Related Models
Bosch SHU8806 UC/12 (FD 8105-)
Bosch SHU8812 UC/12 (FD 8105-)
Bosch SHU8815 UC/12 (FD 8105-)
Bosch SHU8816 UC/12 (FD 8105-)
Whirlpool SHU90000
Whirlpool SHU90001
Whirlpool SHU90002
Whirlpool SHU90010
Whirlpool SHU90040
Whirlpool SHU90041
Whirlpool SHU90050
Whirlpool SHU99000
Whirlpool SHU99001
Bosch SHU9902 UC/06
Bosch SHU9902 UC/06 (FD 7905-7912)
Whirlpool SHU99040
Whirlpool SHU99041
Bosch SHU9905 UC/06
Bosch SHU9905 UC/06 (FD 7905-7912)
Whirlpool SHU99050
Whirlpool SHU99052
Whirlpool SHU99053
Bosch SHU9906 UC/06
Bosch SHU9906 UC/06 (FD 7905-7912)
Bosch SHU9912 UC/06
Bosch SHU9912 UC/06 (FD 7908-8002)
Bosch SHU9912 UC/11
Bosch SHU9912 UC/11 (FD 8002-8003)
Bosch SHU9912 UC/12
Bosch SHU9912 UC/12 (FD 8003-)
Bosch SHU9915 UC/06
Bosch SHU9915 UC/06 (FD 7908-8002)
Bosch SHU9915 UC/11
Bosch SHU9915 UC/11 (FD 8002-8003)
Bosch SHU9915 UC/12
Bosch SHU9915 UC/12 (FD 8003-)
Bosch SHU9916 UC/06
Bosch SHU9916 UC/06 (FD 7908-8002)
Bosch SHU9916 UC/11
Bosch SHU9916 UC/11 (FD 8002-8003)
Bosch SHU9916 UC/12
Bosch SHU9916 UC/12 (FD 8003-)
Bosch SHU9922 UC/12 (FD 8003-)
Bosch SHU9925 UC/12 (FD 8003-)
Bosch SHU9926 UC/12 (FD 8003-)
Bosch SHU9952 UC/12 (FD 8105 -)
Bosch SHU9955 UC/12 (FD 8105 -)
Bosch SHU9956 UC/12 (FD 8105 -)
Bosch SHV4303 UC/06
Bosch SHV4303 UC/06 (FD 7712-8002)
Bosch SHV4303 UC/11
Bosch SHV4303 UC/11 (FD 8002-8003)
Bosch SHV4303 UC/12
Bosch SHV4303 UC/12 (FD 8003-)
Bosch SHV46C03 UC/14 (FD 8211-)
Bosch SHV4803 UC/06
Bosch SHV4803 UC/06 (FD 7712-7812, 7905-7907)
Bosch SHV4803 UC/07
Bosch SHV4803 UC/07 (FD 7812-7905, 7907-8010)
Bosch SHV4803 UC/12
Bosch SHV4803 UC/12 (FD 8010-)
Bosch SHV66A03 UC/14 (FD 8301-)
Bosch SHV6803 UC/12 (FD 8105 -)
Bosch SHV99A03 UC/14 (FD 8212-)
Hoover SHWA2501A Washer - Top Loading
Hoover SHWA2501W Washer - Top Loading
Hoover SHWA2506A Washer - Top Loading
Hoover SHWA2506AT Washer - Top Loading
Hoover SHWA2506W Washer - Top Loading
Hoover SHWA2506WT Washer - Top Loading
Hoover SHWA2507A Washer - Top Loading
Hoover SHWA2507V Washer - Top Loading
Hoover SHWA2507W Washer - Top Loading
Bosch SHX33A02 UC/14 (FD 8211-)
Bosch SHX33A05 UC/14 (FD 8211-)
Bosch SHX33A06 UC/14 (FD 8211-)
Bosch SHX43E02 UC/14 (FD 8211-)
Bosch SHX43E05 UC/14 (FD 8211-)
Bosch SHX43E06 UC/14 (FD 8211-)
Bosch SHX46A02 UC/14 (FD 8211-)
Bosch SHX46A05 UC/14 (FD 8211-)
Bosch SHX46A06 UC/14 (FD 8211-)
Bosch SHX46A07 UC/14 (FD 8211-)
Bosch SHX46B02 UC/14 (FD 8211-)
Bosch SHX46B05 UC/14 (FD 8211-)
Bosch SHX46B06 UC/14 (FD 8211-)
Bosch SHX46B07 UC/14 (FD 8211-)
Bosch SHX56B02 UC/14 (FD 8211-)
Bosch SHX56B05 UC/14 (FD 8211-)
Bosch SHX56B06 UC/14 (FD 8211-)
Bosch SHX99B05 UC/14 (FD 8212-)
Bosch SHX99B06 UC/14 (FD 8212-)
Bosch SHY56A02 UC/14 (FD8301-)
Bosch SHY56A05 UC/14 (FD8301-)
Bosch SHY56A06 UC/14 (FD8301-)
Bosch SHY66C02 UC/14 (FD8301-)
Bosch SHY66C05 UC/14 (FD8301-)
Bosch SHY66C06 UC/14 (FD8301-)
Bosch SHY99A02 UC/14 (FD 8212-)
Bosch SHY99A05 UC/14 (FD 8212-)
Bosch SHY99A06 UC/14 (FD 8212-)
Amana SI19E Ref - SXS/I&W
General Electric SIG7010ET1WG Electric dryer
International SILVER22 Ref - SXS/I&W
International SILVER24 Ref - SXS/I&W
Maytag SK525-2W  Ref - Sxs
Maytag SK535-2  Ref - SXS/I&W
Gaggenau SK590-2  Ref - Bottom Mounts
Hardwick SKG4622MGA639R Range - F/s Cont Clean Gas
Hardwick SKG4622MGW639R Range - F/s Cont Clean Gas
Hardwick SKG9611A540R Range - F/s Cont Clean Gas
Hardwick SKG9611W540R Range - F/s Cont Clean Gas
Amana SKI22F Ref - SXS/I&W
Amana SKI22F-A Ref - SXS/I&W
Amana SKI22F-C Ref - SXS/I&W
Amana SKI22F-G Ref - SXS/I&W
Amana SKI22FL Ref - SXS/I&W
Hardwick SKJ7141819DE Walloven - Cont Clean Gas
Maytag SL10AA Stacked Laundry - Ele
Maytag SL10AA-A01 Stacked Laundry - Ele
  #2 (permalink)
Old 12-10-2010, 05:16 PM
Junior Member
glbgroup is on a distinguished road
Default Bosch SHU8805 no sprayer pressure, low flow
I have exactly the same situation. I replaced the 263314 pump-housing after taking the motor out and noticing the thin side of it was damaged. No difference. I replaced the motor. No difference. I'm not posting my question on different forums trying to get a solution.
I'll share if I get one. It's a great dishwasher, hate to throw it away over something trivial.
Good Luck!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch Circulation Pump cjmdeemer Dishwasher Repair 0 02-11-2010 04:39 PM
bosch circulation pump installation newcastle Dishwasher Repair 0 01-22-2010 11:06 AM
Replacing a Bosch Circulation Pump for Dishwasher sabphi Dishwasher Repair 1 12-29-2009 09:25 AM
BOsch DW Circulation Pump keeps leaking! vintris Dishwasher Repair 0 11-20-2008 05:40 AM
Bosch circulation pump et_lambert Dishwasher Repair 1 02-29-2008 09:37 AM
