Discuss
Bosh Dishwasher noise
 in
Dishwasher Repair
Dishwasher makes loud vibrating noise at the beginning of the cycle and several times during cycle and at cycle end.
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosh Dishwasher noise
  #1 (permalink)
Old 12-20-2007, 02:34 PM
phayburnsr phayburnsr is offline
Junior Member
phayburnsr is on a distinguished road
Default Bosh Dishwasher noise
Model Number: SHE44C   Brand: Bosch   Age: 1 - 5 years
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-20-2007, 05:39 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Check if the noise is coming from the water valve under the sink when the dishwasher is filling with water. Very possible a vibrating washer.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 12-20-2007, 08:26 PM
okbobcats okbobcats is offline
Senior Expert
APP Volunteer
okbobcats is on a distinguished road
Default Pump
Or it also could be the pump out pump. Is you pull off the kick panel in front you can see and even touch the discharge pump. Its on the left front side . When its making this noise put a little pressure on the pump. If noise stops then its your pump.
  #4 (permalink)
Old 12-21-2007, 08:18 AM
kawfeeman kawfeeman is offline
Senior Expert
APP Volunteer
kawfeeman is on a distinguished road
Default
i have also seem some some food stuffs get stuck in circ pump impeller and cause a little vibration to sometimes...
__________________
regards
jim
  #5 (permalink)
Old 12-22-2007, 07:09 AM
Junior Member
Default
The noise doesn't occur during the fill cycle. Seems to be only when discharging water. The machine is only 14 mo. old. I suspect the noise is coming from the pump, probably something stuck, but I don't know how to fix. Do I get at the pump from inside or underneath the machine?
  #6 (permalink)
Old 12-22-2007, 10:07 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
If the dishwasher is only 14 months old then it's still under the manufacturer warranty.
Do not do anything and call the Bosch.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dishwasher noise tim h Dishwasher Repair 4 11-17-2007 10:42 AM
Dishwasher noise and no water ferfer Dishwasher Repair 1 11-16-2007 07:52 PM
Dishwasher noise and no water ferfer Dishwasher Repair 2 11-16-2007 07:03 PM
Bosch dishwasher makes terrible noise, but still washes sueandrob Dishwasher Repair 2 10-14-2007 10:44 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
