| » Dishw Dispenser Door Doesn't Lock SHU6806UC/UC12 |
Model Number: SHU6806UC/UC12 Brand: Bosch Age: 1 - 5 years
I have a Bosch SHU6806UC/UC12, FD8203140057. The soap dispenser door will not stay closed. I removed the dipenser door:
- Spring looks good - Blue plastic hook latch looks good, no sign of wear - Door looks good where the blue hook latch catches it - There might be a slight bow in the dispenser door, not sure The door replacement is easy....however if I have to replace the blue latch, how is that done? Regards, Jack Crowley jack@jackcrowley.com Ads By Google Related Models |
Hi Jack,
The replacement instructions are attached to the reply. Here are the breakdown diagrams and Replacement parts for BOSCH SHU6806 UC/12 (FD 8003-) | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Have you tryed to do it? I believe as soon as you will do it you'll see how it goes.
__________________
Remove the outer door panel to see and access the dispenser. I hope it will make it easier.
__________________
Quote:
I'm not sure what you mean? Does the broken latch come out by prying? And the new one sanp in place by reinserting it? Or do you take the front cover off the dishwasher and manipulate the dispenser in some manner? Any photos or diagrams available? Thanks for your help. |
| Display Modes | |
| Bosch SHU6806UC/12 - Not circulating water well | wmako | Dishwasher Repair | 7 | 08-18-2010 07:29 AM |
| Door will not lock | hossross | Washer Repair | 1 | 03-24-2010 11:30 AM |
| Bosch SHU5315 UC12 control module shorted | tbosch | Dishwasher Repair | 5 | 02-20-2009 01:07 AM |
| F9 code Oven turns off,lock light turns on,door does not lock | darling132 | Oven Repair (including Ranges and Cooktops) | 1 | 11-12-2008 02:06 PM |
| door lock | gpc52 | Washer Repair | 1 | 10-29-2007 04:04 PM |
