dlphnstrkr
#1 Posted : Friday, June 5, 2009 3:53:56 AM(UTC)
dlphnstrkr
turned circuit on,and the normal load key flashes but won't start.hit cancel key and the normal key and rinse only key flashes. if you hit cancel again 2 dashes apear in the status window,hit cancel again and the 2 dashes go away. thanks in advance for any help.
#2 Posted : Friday, June 5, 2009 4:38:46 AM(UTC)
Replacement parts for WHIRLPOOL KUDS01IJBS0 | AppliancePartsPros.com
Here is the tech sheet
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208269519.pdf
Also here is a service manual, not the greatest I've see but may be of some use
https://secured.whirlpoo...800643b6d/$FILE/KD01.pdf
Sounds like either the control board or the key pad is difficult to confirm which it is, so best way is to check the keypad, if OK then by default it is probably the control board.
Could be a stuck key
Try to run the diagnostics
Check the keypad with a meter for the stuck key
If it is a stuck key the keypad will have to be replaced,
Could try cleaning the connector but this usually only applies to opens not shorts (stuck key)
RIBBON CABLE CLEANING
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
Am off to the lake today so will not be available till Monday/Tuesday but there are many other on this forum who can give additional assistance if needed.
my dishwasher won't start a cycle (Dishwasher Repair)
by Guest 1/13/2023 9:06:08 PM(UTC)
Frigidaire dishwasher won't start, all lights are blinking (Dishwasher Repair)
by Guest 11/22/2021 4:33:30 PM(UTC)
Frigidaire Dishwasher Won't Start (FFBD2406NS9B) (Dishwasher Repair)
by Radamis 8/3/2020 8:14:55 AM(UTC)
Viking DDB325SS Dishwasher won't start (Dishwasher Repair)
by tmman 6/10/2020 6:44:15 AM(UTC)
Bosch dishwasher won't start after power surge (Dishwasher Repair)
by Larry120 7/17/2018 11:07:27 AM(UTC)
Bosch dishwasher won't start -- display flashes time (Dishwasher Repair)
by rsilk 6/28/2018 6:21:47 PM(UTC)
Dishwasher won't start when house is too cold (Dishwasher Repair)
by manshack_one 1/2/2018 8:13:29 AM(UTC)
dishwasher won't start (Dishwasher Repair)
by goosemasterkl 9/6/2017 5:03:10 PM(UTC)
Ge dishwasher won't start (Dishwasher Repair)
by gegerva 10/9/2016 5:45:31 AM(UTC)
GE dishwasher won't start (Dishwasher Repair)
by tyanbinh 6/10/2016 7:01:58 PM(UTC)
Dishwasher won't start cycle (Dishwasher Repair)
by fugue 4/16/2016 4:33:36 AM(UTC)
Maytag dishwasher won't start unless I manually hold door closed (Dishwasher Repair)
by RepairKing53 1/29/2016 10:14:13 AM(UTC)
by Tricjabs 1/26/2016 5:41:06 PM(UTC)
by Strum310 11/15/2015 5:57:23 PM(UTC)
by dhbrittain 9/9/2015 3:35:11 PM(UTC)
