Discuss
Bosch DW runs a long time
 in
Dishwasher Repair
I have a Bosch SHE46C DW. It runs for a long time, ultimately getting stuck on "1". Similiar to some
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch DW runs a long time
  #1 (permalink)
Old 11-19-2011, 09:09 PM
Junior Member
Ted O is on a distinguished road
Default Bosch DW runs a long time
Model Number: SHE46C05UC/43   Brand: Bosch   Age: 1 - 5 years
Similiar to some of the previous posts.
Is the SHE same/similiar to SHU?
None of the prior posts seem to be for this model so I wanted to verify a few things before I buy the new controller.
Is the relay on the controller?...so if I buy the new controller the relay is also replaced?
Prior to purchasing the controller, should I rule out any of the other elements such as the heating element? Or, based upon your experince, is the controller most likely the culprit?
Is there another component in the DW that caused this? Or just a bad make of a board?
I will probably take the DW door apart tomorrow to investigate the circut panel.
Many thanks.
Ads By Google
Related Models
Whirlpool SHF3800W0
Whirlpool SHF3800W1
Whirlpool SHF3801W0
Whirlpool SHF3804W0
Whirlpool SHF3804W2
Whirlpool SHF4500W0
Whirlpool SHF5500W0
Whirlpool SHF5501W0
Whirlpool SHF5504W0
Whirlpool SHF5584P0
Whirlpool SHF5584P1
Whirlpool SHF5584P2
Whirlpool SHF5800W0
Whirlpool SHF5800W1
Whirlpool SHF5801W0
Whirlpool SHF5801W1
Whirlpool SHF5880P0
Whirlpool SHF5884P0
Whirlpool SHF5884P1
Whirlpool SHF5884P2
Whirlpool SHF6000W0
Whirlpool SHF6000W1
Whirlpool SHF6002W0
Whirlpool SHF7800W0
Whirlpool SHF7800W1
Whirlpool SHF7801W0
Whirlpool SHF7804W0
Whirlpool SHF7804W1
Whirlpool SHF7884P0
Whirlpool SHF7884P1
Whirlpool SHF7884P2
Bosch SHI4302 UC/06 -FD8002
Bosch SHI4302 UC/11 -FD8003
Bosch SHI4302 UC/12
Bosch SHI4306 UC/06 -FD8002
Bosch SHI4306 UC/11 -FD8003
Bosch SHI4306 UC/12
Bosch SHI66A05 UC/14 (FD 8211-)
Bosch SHI6802 UC/06
Bosch SHI6802 UC/11
Bosch SHI6802 UC/12
Bosch SHI6805 UC/06
Bosch SHI6805 UC/11
Bosch SHI6805 UC/12
Bosch SHI6806 UC/06
Bosch SHI6806 UC/11
Bosch SHI6806 UC/12
Whirlpool SHU30000
Whirlpool SHU30010
Whirlpool SHU30011
Bosch SHU3002
Whirlpool SHU30040
Whirlpool SHU30041
Bosch SHU3006
Whirlpool SHU30110
Bosch SHU3012
Whirlpool SHU30140
Whirlpool SHU30141
Bosch SHU3016
Bosch SHU3032 UC/06 (FD 7908-8002)
Bosch SHU3032 UC/11 (FD 8002-8003)
Bosch SHU3032 UC/12 (FD 8003-)
Bosch SHU3035 UC/12 (FD 8006-)
Bosch SHU3036 UC/06 (FD 7908-8002)
Bosch SHU3036 UC/11 (FD 8002-8003)
Bosch SHU3036 UC/12 (FD 8003-)
Bosch SHU3132 UC/12 (FD 8105-)
Bosch SHU3135 UC/12 (FD 8105-)
Bosch SHU3136 UC/12 (FD 8105-)
Bosch SHU3302 UC/06 (FD 7902-8003)
Bosch SHU3302 UC/11 (FD 8003-8003)
Bosch SHU3302 UC/12 (FD 8003 -)
Bosch SHU3305 UC/06 (FD 7902-8003)
Bosch SHU3305 UC/11 (FD 8003-8003)
Bosch SHU3305 UC/12 (FD 8003 -)
Bosch SHU3306 UC/06 (FD 7902-8003)
Bosch SHU3306 UC/11 (FD 8003-8003)
Bosch SHU3306 UC/12 (FD 8003 -)
Bosch SHU3307 UC/12 (FD 8005 -)
Bosch SHU3322 UC/06
Bosch SHU3322 UC/11
Bosch SHU3322 UC/12
Bosch SHU3322 UC/12 (FD 8003-)
Bosch SHU3326 UC/06
Bosch SHU3326 UC/11
Bosch SHU3326 UC/12
Bosch SHU3326 UC/12 (FD 8003-)
Bosch SHU3336 UC/06
Bosch SHU3336 UC/11
Bosch SHU3336 UC/12
Bosch SHU3336 UC/12 (FD 8003-)
Bosch SHU33A02 UC/14 (FD 8211-)
Bosch SHU33A06 UC/14 (FD 8211-)
Bosch SHU33AC02 UC/14
Bosch SHU33AC06 UC/14
Whirlpool SHU40000
Whirlpool SHU40010
Whirlpool SHU40011
Bosch SHU4002 UC/06
Whirlpool SHU40040
Whirlpool SHU40041
Bosch SHU4006 UC/06
Bosch SHU4016 UC/06
Bosch SHU4022 UC/06
Bosch SHU4026 UC/06
Bosch SHU4036 UC/06
Bosch SHU4302 UC/06 (FD 7705-7912)
Bosch SHU4302 UC/11 (FD 8001-8003)
Bosch SHU4302 UC/12 (FD 8003-)
Bosch SHU4306 UC/06 (FD 7705-7912)
Bosch SHU4306 UC/11 (FD 8001-8003)
Bosch SHU4306 UC/12 (FD 8003-)
Bosch SHU4312 UC/06 (FD 7701-7912)
Bosch SHU4312 UC/11 (FD 8001-8003)
Bosch SHU4312 UC/12 (FD 8003-)
Bosch SHU4316 UC/06
Bosch SHU4316 UC/11
Bosch SHU4316 UC/12
Bosch SHU4322 UC/12
Bosch SHU4322 UC/12 (FD 8003-)
  #2 (permalink)
Old 11-21-2011, 10:16 AM
Junior Member
satabdudes is on a distinguished road
Default Water hot?
Hi Ted,
I have a Bosch DW and it was running too long. It was not drying up correctly and failed at melting the cap of a "dishwasher magic" bottle. The PCB had a black spot and was definitely lacking solder. Added solder and the thing is better than new. I guess the solder was never really good.
YMMV, but I'd check the PCB for an obvious brown/dark spot and a bad solder.
Cheers!
  #3 (permalink)
Old 11-23-2011, 11:50 AM
Junior Member
Default fixed!!!
satabdudes
I took the door off and looked at the circut panel.
The bad spot was very visable.(see photo attached)
5 minute solder job and the DW is running as good as new.
Thanks for the advice.
For any other viewers, simple project. Probably saved $100!!!!
Hardest part was getting the plastic cover off the circut board.
There are about 6 little (hidden) tabs to depress on the front in addition to the two (obvious) tabs on the sides.
Be Well
Ted O.
  #4 (permalink)
Old 11-28-2011, 07:11 AM
Junior Member
Default
Glad it helped Ted.
Mine was not as black as yours.
Depending on how good your solder is and how "resistive" the black part is, you may have the same problem again in a few months/years. What I would do is use an 18ga single strand wire (or just some small wire) and loop it on top of the 3 pins that are on the "black island" on your picture. That will solve the problem forever.
At this point, just keep using it and if it goes again, just put this wire on,
Did you clean the dark spot (soot) before soldering?
Cheers!
  #5 (permalink)
Old 12-05-2012, 06:28 PM
Junior Member
Default Broke again
satabdudes...well here I am 1 year later and I am having the same issue. The DW stopped working a few weeks ago. I opened up the panel to find the solder gone again. I tried to re-solder. works intermitantly...not dependable.
I am going to try soldering on the wire to the three posts as you suggested to see how that works. I hope you were serious with that recommendation.
I'll report back with results.
Ted O.
  #6 (permalink)
Old 01-27-2013, 06:24 AM
Junior Member
kieda is on a distinguished road
Thumbs up This Fix worked for me as well..
I had the exact same problem: The Bosch dishwasher was running for 3+ hours, the time display
would show very odd times (For instance, it would start at 180 minutes, then go down to 1 minute , then back up to 30 minutes, then back to 1 minute.
The dishwasher did not sound right: Water was moving around inside but the arms were not spraying.
I took the front panel off and removed the control module and opened it up and
just as described above the solder joint was gone. So I resoldered and added extra copper wire, as suggested above. Put it back together and it is working
just like new. Thanks for the help.
If anyone else wants to do this, the clue for getting to the circuit card is the following: You need to completely remove the front panel control board from the
dishwasher. After unscrewing the small metal screws from inside the dishwasher, the front panel will be freed. disconnect all the wire connectors (They are keyed for each individual slot, so you cannot reassemble incorrectly). The ground wire has a little tab you must compress to make it release.
You then need to pop the plastic front panel (with buttons) off the metal frame, and then pop the control unit (encased in plastic) out of the metal frame. Both of these are pretty easy if you push back the locking tabs. and twist the panel or control unit in the correct direction. The control panel sort of pivots or swivels out of the frame; it does NOT come straight out.
Finally , to open the control unit there are six plastic locking tabs. The two on
the outside are obvious, but there are four tiny ones on the backside sort of behind the connector row. They are `sunken in', meaning they are sort of interior to the plastic clamshell , accessible through four square holes on the backside of the clamshell. Each hole is a little bit larger than a blade of a standard flat head screwdriver. Using a miniature flat head screwdriver, you should be able to carefully compress one side of each latch and detach it from the other. Once all six latches are opened/freed, the clamshell pivots open.
This worked great: Thanks!
  #7 (permalink)
Old 01-29-2013, 09:06 AM
Junior Member
OsageBeachKat is on a distinguished road
Default
This is EXACTLY what my Bosch is doing and I found a recall here:
Bosch Home Appliances
Repairman coming to REPLACE the control module! At Bosch's expense!
  #8 (permalink)
Old 02-03-2013, 02:12 PM
Junior Member
Cool Bosch recall
Great news...I checked mine. It was the correct model but the wrong
serial number for the recall. So there was no free Bosch serve for me. It was a good thing that i was able to fix it using the above suggestions
  #9 (permalink)
Old 03-14-2013, 05:10 PM
Junior Member
InSearchOfAnswers is on a distinguished road
Default
If your dishwasher is NOT on the recall list, search with "bosch relay recall" on Youtube for the fix.
  #10 (permalink)
Old 03-18-2013, 07:32 PM
Junior Member
millersj is on a distinguished road
Default SHX45M05UC Bosch Dishwasher....bad solder
I did just like the guys above suggested and it worked. However, I opened the dishwasher mid-cycle and was concerned that the water temp just wasn't HOT. It felt pretty luke-warm and that doesn't seem right. Any thoughts?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch DWasher - Runs too Long rtfisher Dishwasher Repair 5 01-27-2013 06:33 AM
bosch dishwasher runs too long dmacd33 Dishwasher Repair 3 01-27-2013 06:30 AM
Kitchen Aid Dishwasher runs for a very long time GNACK Dishwasher Repair 0 02-13-2011 10:40 AM
Refrigerator runs a long time then stops for only 5 minutes Sam94 Refrigerator & Freezer Repair 2 05-15-2010 02:02 PM
refrigerator runs long time shuts off and back on within 10 minutes dthodman Refrigerator & Freezer Repair 1 06-09-2009 07:49 AM
