Discuss
Dishwasher stopped operating
 in
Dishwasher Repair
My KitchenAid dishwasher (Model KUDS01IJBS0 and Serial Number FL1813031) has stopped operating. I turned off the power to it for
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher stopped operating
  #1 (permalink)
Old 12-19-2007, 08:43 AM
KKaz KKaz is offline
Junior Member
KKaz is on a distinguished road
Default Dishwasher stopped operating
Model Number: KUDS01IJBS0   Brand: Kitchen Aid   Age: 5 - 10 years
My KitchenAid dishwasher (Model KUDS01IJBS0 and Serial Number FL1813031) has stopped operating. I turned off the power to it for over 12 hours to see if it required a reset, but the dishwasher has the same problem. Upon power up, the "Add a Dish" LED is flashing with no other indications. If I hit the Start button, the "Rinse On" LED starts flashing with the "Add a Dish" LED. Pressing the other mode buttons didn't illuminate their respective LEDs. After pressing the "Cancel/Drain" button a few times, the Status Display would show just two dashes.
Also, once I was able to get the normal dishwashing mode to start (after powering it off for a while), but it stopped after about 15 minutes with the "Add a Dish" LED flashing and the Status Display just showing the two dashes.
I verified that the door switch is operating properly by jumpering it out and the problem persists. Also, I couldn't enter the diagnostic modes by doing the key sequences.
Should I replace the control module, the touch panel, or both?
Thanks!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-07-2008, 01:37 PM
FrustratedButDetermined FrustratedButDetermined is offline
Junior Member
FrustratedButDetermined is on a distinguished road
Default KUDS01 I LBS0 - flashing 'add dish' light & unresponsive
My KUD01 is doing exactly the same thing. You described it well.
I replaced the control/timer circuit board to no avail. I'm guessing that replacing it won't help your problem either.
I jumpered each of the microswitches in turn (including the door latch). When I disconnected the vent thermistor, and cycled the power, it behaved differently, so I replaced the vent assembly (which contains a new thermistor). Still no joy.
I disassembled the 'soil sensor'/pressure switch. I found the (internal) contacts were badly corroded. So I cleaned it all up, verified it worked (using an ohmmeter). Yet no change in the behaviour.
I hadn't considered the touch panel (the 'delay' button is a little soft) as a possibility, otherwise I'm running out of ideas.
Any thoughts anyone?
PS. The main motor when out 2 years ago and I replaced that successfully. The door gasket began to leak a year ago, so I replaced that. Pretty soon, I'll have replaced everything but the racks and basin!
  #3 (permalink)
Old 01-11-2008, 07:29 AM
Junior Member
Default Touch Pad May Be Defective
The service guy was just here and confirmed with KitchenAid that based on the symtoms and the flashing Normal LED, the keypad is bad. I confirmed with the technician that I tested the keypad with a digital multimeter, but he said replacing the touchpad has fixed problems in the past where the pad tested just fine. My advice, try replacing the touchpad next.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore dishwasher just stopped scooter6580 Dishwasher Repair 5 12-30-2007 06:57 PM
Microwave not operating DrewG Microwave Repair 0 12-09-2007 09:05 AM
Operating Refrigerator in Cold Temperature Environments SUhoopfan Refrigerator & Freezer Repair 1 12-06-2007 03:14 AM
Stopped Tumbling Beth Dryer Repair 1 11-25-2007 07:43 AM
It just stopped durf23112 Refrigerator & Freezer Repair 1 11-18-2007 10:35 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
