| » Bosch |
Model Number: SHU5302UC/06 Brand: -brand- Age: 5 - 10 years
Will not cycle except on rinse/hold. It will reach a point after filling when it just keeps running at that spot, e.g., will run at 84 minutes forever. I have to let it run for a while, then drain, then run the rinse/hold cycle to get the dishes clean.
The machine will not cycle in either the regular or delicate cycle, but will for the rinse/hold cycle. It will fill up and run to a time point on the display, e.g., 84 minutes, and keep running at that display time forever. The only way I can get my dishes clean is to let it run for a half hour or so, then cancel/drain, then run the rinse/hold cycle and let air dry.
replace control module part # 266746... ( more than likely heater is not being activated... ) if you are so inclined you can remove the control module from the control panel and open it up and check and see that there will be a burn mark on one of the relays on the pc side of the board.. )
__________________
regards jim |
| Display Modes | |
| Bosch Dilemma | cgourzong | Oven Repair (including Ranges and Cooktops) | 1 | 05-11-2011 10:23 PM |
| Bosch | christostrat | Washer Repair | 0 | 12-19-2009 01:39 PM |
| bosch d/w | misterfixall | Dishwasher Repair | 0 | 09-15-2009 01:17 PM |
| Bosch dishwasher | kjvirtue | Dishwasher Repair | 3 | 02-04-2009 08:00 PM |
| help with bosch d/w | danimaldds | Dishwasher Repair | 3 | 08-12-2008 03:22 PM |
