Discuss
Drain Pump
 in
Dishwasher Repair
My otherxise faultless dw stopped draining. So I checked the drain hose to be sure the outlet into the garbage
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Drain Pump
  #1 (permalink)
Old 08-06-2007, 06:34 AM
loadster loadster is offline
The Dishwasher Conqueror
loadster will become famous soon enough
Angry Drain Pump
Model Number: SHU4306   Brand: Bosch   Age: 1 - 5 years
My otherxise faultless dw stopped draining. So I checked the drain hose to be sure the outlet into the garbage disposer was clear. Good. Checked drain hoses for crimps or obstruction. Good. Ran self-check diagnostics. No faults except had to manually bail out gallons of water from tank base. Wrestled dw out of cabinet and took extensive on the job training in draining and gaining access to components of dw. Checked resistance on drain motor. Measured 16.5 ohms which indicated good. Checked control board for possible cold solder joints or burnt connections; none found. Finally discovered cover plate over drain impeller in bottom of collector in tank and removed plate. Manually turning sprocket felt like turning sandy blades in bucket of loose bolts and springs. Not smooth. Presumed bearing had failed. Have ordered new pump ($64) and expecting new joys in hand cuts trying to install. Hoping for reincarnated trouble-free dish-maid. Lesson learned: access mechanical shafts on motors and check for free-wheeling when possible. If circulation pump fails, may have to find more serviceable dw.
Related Models
Bosch SHU4306 UC/06 (FD 7705-7912)
Bosch SHU4306 UC/11 (FD 8001-8003)
Bosch SHU4306 UC/12 (FD 8003-)
Bosch SHU4312 UC/06 (FD 7701-7912)
Bosch SHU4312 UC/11 (FD 8001-8003)
Bosch SHU4312 UC/12 (FD 8003-)
Bosch SHU4316 UC/06
Bosch SHU4316 UC/11
Bosch SHU4316 UC/12
Bosch SHU4322 UC/12
Bosch SHU4322 UC/12 (FD 8003-)
Bosch SHU4326 UC/12
Bosch SHU4326 UC/12 (FD 8003-)
Bosch SHU43C02 UC/14 (FD 8211-)
Bosch SHU43C05 UC/14 (FD 8211-)
Bosch SHU43C06 UC/14 (FD 8211-)
Bosch SHU43C07 UC/14 (FD 8211-)
Bosch SHU43E02 UC/14 (FD 8211-)
Bosch SHU43E05 UC/14 (FD 8211-)
Bosch SHU43E06 UC/14 (FD 8211-)
Bosch SHU43E07 UC/14 (FD 8211-)
Whirlpool SHU45010
Whirlpool SHU45020
Whirlpool SHU50000
Whirlpool SHU50001
Whirlpool SHU50002
Whirlpool SHU50010
Whirlpool SHU50040
Whirlpool SHU50041
Whirlpool SHU50043
Bosch SHU5302 UC/06 (FD 7705-7912)
Bosch SHU5302 UC/11 (FD 8001-8003)
Bosch SHU5302 UC/12 (FD 8003-)
Bosch SHU5304 UC/06 (FD 7705-7912)
Bosch SHU5304 UC/11 (FD 8001-8003)
Bosch SHU5304 UC/12 (FD 8003-)
Bosch SHU5305 UC/06 (FD 7705-7912)
Bosch SHU5305 UC/11 (FD 8001-8003)
Bosch SHU5305 UC/12 (FD 8003-)
Bosch SHU5306 UC/06 (FD 7705-7912)
Bosch SHU5306 UC/11 (FD 8001-8003)
Bosch SHU5306 UC/12 (FD 8003-)
Bosch SHU5307 UC/12 (FD 8003-)
Bosch SHU5312 UC/06
Bosch SHU5312 UC/11
Bosch SHU5312 UC/12
Bosch SHU5314 UC/06
Bosch SHU5314 UC/11
Bosch SHU5314 UC/12
Bosch SHU5315 UC/06
Bosch SHU5315 UC/06 (FD 7705-7912)
Bosch SHU5315 UC/11
Bosch SHU5315 UC/11 (FD 8001-8003)
Bosch SHU5315 UC/12
Bosch SHU5315 UC/12 (FD 8003-)
Bosch SHU5316 UC/06
Bosch SHU5316 UC/11
Bosch SHU5316 UC/12
Bosch SHU5317 UC/12
Bosch SHU53A02 UC/14 (FD 8211-)
Bosch SHU53A05 UC/14 (FD 8211-)
Bosch SHU53A06 UC/14 (FD 8211-)
Bosch SHU53E02 UC/14 (FD 8211-)
Bosch SHU53E05 UC/14 (FD 8211-)
Bosch SHU53E06 UC/14 (FD 8211-)
Whirlpool SHU55000
Whirlpool SHU55010
Whirlpool SHU55040
Whirlpool SHU55041
Whirlpool SHU55042
Whirlpool SHU60010
Whirlpool SHU60011
Whirlpool SHU60020
Bosch SHU66C02 UC/14 (FD 8211-)
Bosch SHU66C05 UC/14 (FD 8211-)
Bosch SHU66C06 UC/14 (FD 8211-)
Bosch SHU66C07 UC/14 (FD 8211-)
Bosch SHU66E02 UC/14 (FD 8211-)
Bosch SHU66E05 UC/14 (FD 8211-)
Bosch SHU66E06 UC/14 (FD 8211-)
Bosch SHU66E07 UC/14 (FD 8211-)
Bosch SHU6802 UC/06 (FD 7705-7912)
Bosch SHU6802 UC/11 (FD 8001-8003)
Bosch SHU6802 UC/12 (FD 8003-)
Bosch SHU6805 UC/06 (FD 7705-7912)
Bosch SHU6805 UC/11 (FD 8001-8003)
Bosch SHU6805 UC/12 (FD 8003-)
Bosch SHU6806 UC/06 (FD 7705-7912)
Bosch SHU6806 UC/11 (FD 8001-8003)
Bosch SHU6806 UC/12 (FD 8003-)
Whirlpool SHU70000
Whirlpool SHU70001
Whirlpool SHU70010
Whirlpool SHU70040
Whirlpool SHU70041
Whirlpool SHU70050
Whirlpool SHU70051
Whirlpool SHU70052
Whirlpool SHU75000
Whirlpool SHU75010
Whirlpool SHU75040
Whirlpool SHU75042
Whirlpool SHU80000
Whirlpool SHU80001
Whirlpool SHU80010
Whirlpool SHU80040
Whirlpool SHU80041
Whirlpool SHU80042
Bosch SHU8802 UC/12 (FD 8105-)
Bosch SHU8805 UC/12 (FD 8105-)
Bosch SHU8806 UC/12 (FD 8105-)
Bosch SHU8812 UC/12 (FD 8105-)
Bosch SHU8815 UC/12 (FD 8105-)
Bosch SHU8816 UC/12 (FD 8105-)
Whirlpool SHU90000
Whirlpool SHU90001
Whirlpool SHU90002
Whirlpool SHU90010
Whirlpool SHU90040
Whirlpool SHU90041
  #2 (permalink)
Old 08-07-2007, 07:35 PM
Admin / APP Team's Avatar
Admin / APP Team Admin / APP Team is offline
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
Nice! From now on you shall be known as "loadster, The Dishwasher Conqueror"! Yeah, I know. That's all I could think of.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Main pump motor is not activated. gebman1 Dishwasher Repair 0 07-31-2007 11:05 PM
Replacing Pump pdiddy Washer Repair 0 07-23-2007 01:43 AM
Changing Pump pdiddy Washer Repair 1 07-20-2007 07:05 PM
