Our dishwasher doesn't drain..., I've checked the hose to the garbage disposal, inspected the checkvalve, inspected the impeller and found no problems. When you hit the Cancel/Drain button it runs but doesn't drain. I didn't take the pump assembly apart any farther than the impeller, do I need too or do you think it's the pump?
