Discuss
Bosch SHU43Turns Off
 in
Dishwasher Repair
Hello, I have a SHU4306 Bosch dishwasher. I have fixed (resoldered) the Heater relay on this DW already. I have
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch SHU43Turns Off
  #1 (permalink)
Old 12-17-2007, 02:18 PM
DaleHurd DaleHurd is offline
Junior Member
DaleHurd is on a distinguished road
Default Bosch SHU43Turns Off
Model Number: SHU43   Brand: Bosch   Age: 5 - 10 years
Hello,
I have a SHU4306 Bosch dishwasher. I have fixed (resoldered) the Heater relay on this DW already. I have a new issue. When I push the On/off button the DW doesn't always start. The light will blink on briefly then shut off. If I do this a few time the machine will then start. I suspect a faulty on/off switch or wiring connection. It seems to intermittent to be a control board issue. Are there any other switches I should be checking?
Dale
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-18-2007, 07:24 AM
kawfeeman kawfeeman is offline
Senior Expert
APP Volunteer
kawfeeman is on a distinguished road
Default
check to see if the "hole" where the actual on/ off switch button goes back and forth is dirty.. try pressing the button in all the way slowly ... you may want to try spraying contact cleaner around the button, but it does sound like switch is bad ..
__________________
regards
jim
  #3 (permalink)
Old 12-18-2007, 10:29 AM
Junior Member
Default
Ok took your advice...will keep you posted
  #4 (permalink)
Old 12-19-2007, 08:22 AM
Senior Expert
APP Volunteer
Default
great... good luck..
Merry and Happy !!
__________________
regards
jim
  #5 (permalink)
Old 12-20-2007, 10:39 PM
Junior Member
Default
well,bummer...problem doesn't seem to be in the switch...I replaced the switch and I still have the problem. Would you guess the darn control unit....Ijust seems to act like a bad connection of some sorts
  #6 (permalink)
Old 12-21-2007, 06:12 AM
Senior Expert
APP Volunteer
Default
how are the two / three wires coming into the d/w ? the black and white wires ( and ground ) .. are the wire nuts tight enough ? is there any oxidation or corrosion on those wires ?
__________________
regards
jim
  #7 (permalink)
Old 01-14-2008, 04:24 PM
Junior Member
Default
Well at long last I've gotten to the bottom of it!!!! I resoldered one of the components on the control board! Viola! It works like a charm. FYI it was a rectangular white box maybe 1/2 the size of a sugar cube. 2 contacts were loose.
As an fyi. This is the 2nd control unit repair I've made. I had to resolder the heater relay about a year ago (Fixed the never ending rinse cycle problem)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
bosch sat for 4 months bridgeway Dishwasher Repair 3 11-17-2007 10:52 PM
Bosch dishwasher sherryg Dishwasher Repair 0 10-08-2007 11:46 AM
Bosch won't countdown to zero StratLou Dishwasher Repair 4 09-04-2007 07:28 AM
Bosch Dryer Frank Titoni Dryer Repair 0 09-01-2007 10:26 AM
Bosch dishwasher Elise Dishwasher Repair 2 08-13-2007 07:19 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
