I just purchased a home with a GE profile Triton III and all of the water does not pump out of the tub . I disconnected the drain and held it over a bucket and it pumps (not hard) but stops before the tub is empty . The water is dirty and is over the heating element . Everything else seams to be working properly . I looked for debris on the filter screen but did not remove it . Does this model have a piston ? What do I check first ?
