Discuss
Gaggenau Dishwasher code F
 in
Dishwasher Repair
We have a Gaggenau (Bosch) dishwasher that's giving an F code. The drain pump also seems to be stuck
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Gaggenau Dishwasher code F
  #1 (permalink)
Old 12-16-2007, 08:13 PM
jdcantin jdcantin is offline
Junior Member
jdcantin is on a distinguished road
Default Gaggenau Dishwasher code F
Model Number: GM915-710   Brand: Bosch   Age: 5 - 10 years
We have a Gaggenau (Bosch) dishwasher that's giving an F code. The drain pump also seems to be stuck on. When the reset buttons are held down on restart, the display shows a '21', and when pressed again shows a '4'. I'm hoping we can simply replace a part or two and get the unit running again.
Separately, the unit also slowly fills with water when left empty and idle. This takes about 4-5 days before it's full enough to overflow. Is there a particular part that often causes this problem? A seal/gasket?
Jeff
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-16-2007, 08:56 PM
kawfeeman kawfeeman is offline
Senior Expert
APP Volunteer
kawfeeman is on a distinguished road
Default
very often with these units the watervalve has failed ( slightly ) ... it is allowing water in the tank even though the d/w is not on... water has filled the tank and gotten down into the bottom environment where the styro float mechanism trips a micro switch ... need to disconnect power and remove the water from that basin area in the white plastic environment ( where float is as well as where the circ pump is too.. ) shut water off to d/w and replace inlet valve.. more than likely the inlet valve is your problem ( MIGHT be a leak with circ pump, but unlikely ... )
__________________
regards
jim
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
F08 code grivk Oven Repair (including Ranges and Cooktops) 0 11-23-2007 10:34 AM
f3 code....still beermebeerme Oven Repair (including Ranges and Cooktops) 1 11-05-2007 05:30 AM
F3 code...again beermebeerme Oven Repair (including Ranges and Cooktops) 1 10-16-2007 10:21 PM
NEW bosch dishwasher will not start code 119 rjake48 Dishwasher Repair 1 10-05-2007 04:45 AM
Dishwasher - Fault Code DIY Napton Dishwasher Repair 1 10-03-2007 05:55 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
