| » Replce Dishwasher door spring |
Model Number: DU800CWDQ4 Brand: Whirlpool Age: 1 - 5 years
My dishwasher's door opens too quickly and guess need a new door spring? If so, how can I change it? Do I need to open the back of door panel?
You might have had one of the springs break. The easiest way to replace or adjust is the pull the unit out of the cabinet about 6 inches and you will see the spring(s) on each side. If you need to replace one, go here to order it. You can also adjusted the door tension by moving the spring a few notches toward the back.
TechnicianBrian |
You can buy such parts from an appliance parts store only.
__________________
Professional appliance repair in Los Angeles, California. |
I've tried for the past hour and a half to put a new spring on my Kitchenaid KUDS01FLSS5 with no success. I can get the spring on but once I try to loop the cord around the wheel and onto the door either the spring pops off or I cannot release enough tension in the spring to pull it all the way around. Is there a special tool to help with this task?
| Display Modes | |
| replace torsion spring in micro door | kendall43 | Microwave Repair | 6 | 07-25-2008 05:08 PM |
| Spring Poppped Off Door Hinge | rblueder | Oven Repair (including Ranges and Cooktops) | 1 | 12-06-2007 05:31 PM |
| Idler Arm spring | JClements | Dryer Repair | 1 | 11-21-2007 01:57 PM |
| repair door spring | Sdemarais | Dishwasher Repair | 1 | 11-18-2007 01:26 PM |
| Dishwasher door spring | wojoe2k7 | Dishwasher Repair | 3 | 08-30-2007 08:31 PM |
