Discuss
Does not fill complete
 in
Dishwasher Repair
I have a Whirpool diswasher that does not fill to the proper level. It fills part way then water shuts
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Does not fill complete
  #1 (permalink)
Old 12-16-2007, 02:57 PM
scotto scotto is offline
Junior Member
scotto is on a distinguished road
Default Does not fill complete
Model Number: DU8900XT-1   Brand: Whirlpool   Age: More than 10 years
I have a Whirpool diswasher that does not fill to the proper level. It fills part way then water shuts off. I can hear the pump sucking air. If I open it, restart the timer to beginning, and restart, It continues to fill and pump no longer cavitates. Is the fill cycle time based? Is it adjustable? I don't see any restriction to slow the water flow unless there is a filter or screen someplace...
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-17-2007, 01:10 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would do is replace the water inlet valve (#26 on the tub break down diagram).
The water inlet valve has a screen inside, which most likely is clogged with a hard water deposits.
- The part number for the water inlet valve is AP3050333
- Here are the break down diagrams for the Whirlpool dishwasher Model DU8900XT1
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer won't complete cycle-grinding noise rebekah Washer Repair 2 12-13-2007 08:20 PM
Bosch dishwasher won't complete cycle brewstmp Dishwasher Repair 5 12-13-2007 08:17 PM
IceMaker won't fill Snowman Refrigerator & Freezer Repair 1 12-02-2007 11:57 PM
wont fill DB1 Dishwasher Repair 2 12-01-2007 05:19 AM
dishwasher instructions to replace complete motor and pump assembly needed Nancy Ramsey Dishwasher Repair 0 10-25-2007 01:22 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
