Discuss
Whirlpool won't cycle, diagnostics work
 in
Dishwasher Repair
At first the only thing it would do is Cancel/Drain. That stopped. Then if I pressed AirDry (or Control
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Whirlpool won't cycle, diagnostics work
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-16-2007, 08:05 AM
drwhite drwhite is offline
Junior Member
drwhite is on a distinguished road
Default Whirlpool won't cycle, diagnostics work
Model Number: GU1200XTKB0   Brand: Whirlpool   Age: 1 - 5 years
At first the only thing it would do is Cancel/Drain. That stopped. Then if I pressed AirDry (or Control lock) with Quick Wash it would go into cancel drain. Everything sounded normal. Then I discovered this site. I did the diagnostics sequence and pressed pots/pans and the sequences operated, but curiously with the Crystal light always on or blinking. After it stopped the crystal indicator light went off. I opened the door and reclosed it and none of the normal buttons work. Did the diagnostics again. Same result.
Of note, not all the indicator lights came on and off during the diagnostics,
just washing, soaking, and drying.
Any clues would help. I suspect a bad keyboard. What procedures needed to check that? Broken ribbon check method?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool AC won't work lemiley Heating, Ventilation, and Air Conditioning (HVAC) 6 08-11-2008 08:50 PM
After Cleaning Cycle - Oven does not work bokeldol Oven Repair (including Ranges and Cooktops) 5 01-09-2008 06:59 PM
No spin on regular cycle, others work klawson Washer Repair 2 12-05-2007 02:58 PM
Spin Cycle will not work Apache6434 Washer Repair 4 11-28-2007 03:55 AM
Washer does not work in gentle cycle hcjr Washer Repair 7 09-22-2007 04:24 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
