| » Kitchenaid dishwasher leaking from bottom |
Model Number: KUDH230BWHO Brand: Kitchen Aid Age: 5 - 10 years
My Kitchenaid dishwasher has developed a minor leak from the bottom front left corner. I took off the bottom panel and watched; late in the cycle (before the rinse) it drips from the overflow switch tube. I took out the switch and it appears to be open on the top, so I'm not sure if I should replace the switch, or if some other problem is causing the basin to overfill?
I'd appreciate any help troubleshooting the cause. Thanks, Ads By Google Related Models |
Model Search Give the float a good cleaning sometimes crud can wick up the water and cause a drip. Check that the unit is level or leaning slightly to the rear. Check the holes in the washer arm sometimes a partial plug can cause the water to spray at a weird angle causing a leak. I find it easiest to clean them when the stuff is is still wet and then use a pair of tweezers to pull the plug out. Check that the overflow tube does not have a small crack. Most units just fill by time and the fill switch is just an overflow protector. Though there are some that use the fill switch as a water level switch, not sure on this unit. Another thing to check is if the unit is pumping out correctly between cycles, if not it may be adding too much water to a unit which already has some water in it. Most common causes for poor pump out are dirty filters or a partially clogged drain.
__________________
- Last edited by denman : 05-26-2009 at 12:56 AM. |
| Display Modes | |
| Dishwasher leaking at bottom of door | dbasili | Dishwasher Repair | 0 | 07-15-2009 04:38 PM |
| Dishwasher leaking from bottom | FPS | Dishwasher Repair | 2 | 04-06-2009 02:19 AM |
| dishwasher leaking at door bottom | LaRue | Dishwasher Repair | 0 | 06-24-2008 11:40 AM |
| dishwasher leaking on the bottom | gerald | Dishwasher Repair | 1 | 10-05-2007 03:52 AM |
| dishwasher leaking at bottom of door | skinnybeak | Dishwasher Repair | 0 | 09-24-2007 05:22 PM |
