Hi We have a Kitchen Aid dishwasher Model KUDi02iRBTO. That is right off the Tag on the washer After running any cycle I notice that there is a little water left in the bottom. You have to get a flashlight on it because the water left is down well under the sprayer arms. So its not alot but its full to the top of the plastic parts (dont know the name for it). With a flashlight you can see the water. So we took it all apart and everything is clean. Nothing is stuck and there is no build up. I did notice I would like to replace the screen. So if you hit the cancel button the water drains. Not sure but I thought it would shut off once all the water was drained when you used the cancel button. It does not so I stop it. All the water is then out. The dishes look clean. Not sure what else to do. Any ideas?
