Discuss
Tappan Dishwasher fills then drains
 in
Dishwasher Repair
My mother's Tappan dishwasher will start a clean cycle fill with water till float shuts water off and then
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Tappan Dishwasher fills then drains
  #1 (permalink)
Old 12-13-2007, 08:00 PM
Henry R Henry R is offline
Junior Member
Henry R is on a distinguished road
Default Tappan Dishwasher fills then drains
Model Number: 61-1147-10   Brand: Tappan   Age: More than 10 years
My mother's Tappan dishwasher will start a clean cycle fill with water till float shuts water off and then it pumps the water out. I have tried to manually cycle the timer with no results. I have also tried to find a schematic to see if I could figure out what was in the circuit.
Henry
Related Models
Frigidaire 61-1157-10-00 Tap(v4) / Undercounter Dishwasher
Frigidaire 61-1160-00 Tap(v2) / 24 " Built - in Dishwasher
Frigidaire 61-1160-10-00 Tap(v1) / 24 " Built - in Dishwasher
Frigidaire 61-1160-23 Tap(v3) / 24 " Built - in Dishwasher
Frigidaire 61-1170-00 Tap(v2) / 24 " Built - in Dishwasher
Frigidaire 61-1170-10-00 Tap(v1) / 24 " Built - in Dishwasher
Amana 610.000 Mwave - Family Size (60 Hz)
Amana 610.001 Mwave - Family Size (60 Hz)
Amana 610.002 Mwave - Family Size (60 Hz)
Maytag 61004752 Misc / Accessory
Maytag 61004753 Misc / Accessory
Maytag 61004754 Misc / Accessory
Maytag 61004755 Misc / Accessory
Maytag 61004756 Misc / Accessory
Magic Chef 6100PRA Range - S/i Std Gas
Magic Chef 6100PRL
Magic Chef 6100PRW Range - S/i Std Gas
Magic Chef 6100PTA Range - S/i Std Gas
Magic Chef 6100PTW Range - S/i Std Gas
Amana 614-2N Room Air Conditioner
Amana 614-2P Room Air Conditioner
Amana 614-2W Room Air Conditioner
Amana 615-2F Room Air Conditioner
Amana 615-2G Room Air Conditioner
Amana 615-2J Room Air Conditioner
Magic Chef 6157WRA Range - S/i Std Gas
Magic Chef 6157WRL
Magic Chef 6157WRW Range - S/i Std Gas
Magic Chef 6157WTA Range - S/i Std Gas
Magic Chef 6157WTV Range - S/i Std Gas
Magic Chef 6157WTW Range - S/i Std Gas
Magic Chef 6157WUA Range - S/i Std Gas
Magic Chef 6157WUW Range - S/i Std Gas
Magic Chef 6157XRA Range - S/i Std Gas
Magic Chef 6157XRL
Magic Chef 6157XRW Range - S/i Std Gas
Magic Chef 6157XTA Range - S/i Std Gas
Magic Chef 6157XTW Range - S/i Std Gas
Magic Chef 6157XUA Range - S/i Std Gas
Magic Chef 6157XUW Range - S/i Std Gas
Amana 619-3P Room Air Conditioner
Amana 619-3W Room Air Conditioner
Maytag 61C Dryer - Gas
Magic Chef 61H*-3KX
Magic Chef 61HA-1 Range - S/i Std Gas
Magic Chef 61HA-3KW Range - S/i Std Gas
Magic Chef 61HA-3KX Range - S/i Std Gas
Magic Chef 61HN-1 Range - S/i Std Gas
Magic Chef 61HN-3KW Range - S/i Std Gas
Magic Chef 61HN-3KX Range - S/i Std Gas
Magic Chef 61HY-1 Range - S/i Std Gas
Magic Chef 61HY-3KW Range - S/i Std Gas
Magic Chef 61HY-3KX Range - S/i Std Gas
Magic Chef 61S04PAA Range - S/i Std Gas
Magic Chef 61S04PAW Range - S/i Std Gas
Magic Chef 61S14WAA Range - S/i Std Gas
Magic Chef 61S14WAW Range - S/i Std Gas
Magic Chef 61S14XAA Range - S/i Std Gas
Magic Chef 61S14XAB Range - S/i Std Gas
Magic Chef 61S14XAW Range - S/i Std Gas
Maytag 61W Dryer - Gas
Hoover 62 Frigidaire/refrigerator
Amana 621-3F Room Air Conditioner
Amana 621-3G Room Air Conditioner
Amana 621-3J Room Air Conditioner
Amana 621-3J-1 Room Air Conditioner
Amana 621-5F Room Air Conditioner
Amana 621-5G Room Air Conditioner
Amana 621-5G-1 Room Air Conditioner
Amana 621-5J Room Air Conditioner
Amana 621.000 Mwave - Family Size (60 Hz)
Amana 621.001 Mwave - Family Size (60 Hz)
Amana 624-3F Room Air Conditioner
Amana 624-3FH Room Air Conditioner
Amana 624-3G Room Air Conditioner
Amana 624-3G-1
Amana 624-3GH Room Air Conditioner
Amana 624-3GH-1
Amana 624-3HW Room Air Conditioner
Amana 624-3J Room Air Conditioner
Amana 624-3J-1 Room Air Conditioner
Amana 624-3JH Room Air Conditioner
Amana 624-3W Room Air Conditioner
Amana 624-5F Room Air Conditioner
Amana 624-5FH Room Air Conditioner
Amana 624-5G Room Air Conditioner
Amana 624-5G-1 Room Air Conditioner
Amana 624-5GH Room Air Conditioner
Amana 624-5GH-1 Room Air Conditioner
Amana 624-5J Room Air Conditioner
Amana 624-5JH Room Air Conditioner
Amana 6243HL Room Air Conditioner
Amana 6243L Room Air Conditioner
Amana 6243P Room Air Conditioner
  #2 (permalink)
Old 12-13-2007, 08:36 PM
kawfeeman kawfeeman is offline
Senior Expert
APP Volunteer
kawfeeman is on a distinguished road
Default
do you ever notice if the pump comes on to circulate water ?
  #3 (permalink)
Old 12-14-2007, 06:01 AM
Junior Member
Default
When the fill stops the pumps comes on and pumps the water out, it does not circulate at all.
  #4 (permalink)
Old 12-14-2007, 04:36 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Remove the bottom panel and check the drain solenoid (#5 on the main motor break down diagram).
It might be stuck in the drain position.
Remove the solenoid and check if the shaft for the drain gate is moving freely. If not, then the pump has to be replaced.
- The part number for the pump is AP2136753
- The part number for the drain solenoid is AP2149163
- Here are the break down diagrams for the Tappan dishwasher Model 61-1147-00-10
__________________
  #5 (permalink)
Old 12-14-2007, 05:38 PM
Junior Member
Default
Thank you very much, Gene. I will try that tomorrow morning when I go and visit her.
Thanks again
Henry
  #6 (permalink)
Old 12-14-2007, 05:57 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Keep me updated, please.
__________________
  #7 (permalink)
Old 12-15-2007, 04:53 PM
Junior Member
Default
The drain solenoid was not stuck, it was free. I moved the lever to check to see if it was stuck, but it was free also. It ran fine after I did this. I am now wondering if something could have been lodged in the drain flap!!!
Thanks again
Henry
  #8 (permalink)
Old 12-15-2007, 07:09 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Very possible a foreign object could obstruct the flapper.
I'm glad you were able to fix it easy.
Merry Christmas and Happy New Year!
__________________
  #9 (permalink)
Old 12-15-2007, 07:59 PM
Junior Member
Default
Thank you and the same to you
Henry
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
fills up and drains immediately dennis b Washer Repair 3 12-14-2007 12:41 PM
Fills and drains......no spin danc44 Washer Repair 5 12-01-2007 08:49 PM
Dishwasher fills then immediately drains macmantim Dishwasher Repair 0 12-01-2007 10:44 AM
Washer drains but won't spin KAP Washer Repair 3 11-09-2007 12:59 PM
Dishwasher fills and drains and runs trough cycles but doesnt wash ryan6663 Dishwasher Repair 1 10-24-2007 05:11 PM
