Discuss
Where is moisture sensor?
 in
Dishwasher Repair
My dishwasher is stuck in drain cycle. We had a water leak around the door seal. Crud builds up along
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Where is moisture sensor?
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-13-2007, 02:23 PM
brian44 brian44 is offline
Junior Member
brian44 is on a distinguished road
Default Where is moisture sensor?
Model Number: SHE44C02UC   Brand: Bosch   Age: 1 - 5 years
My dishwasher is stuck in drain cycle. We had a water leak around the door seal. Crud builds up along the seal then it leaks. We clean it off and it stops leaking. This time apparently moisture got to a sensor? Where is it?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-13-2007, 04:59 PM
leggman leggman is offline
Junior Member
leggman is on a distinguished road
Default
take the kick panel off and sopp up the water in the base assytheres a float just left of ctr. that runs drain pump and goes into lockout.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Sensor Dry Mode drew Dryer Repair 1 12-13-2007 07:32 PM
Sensor Pad Duke Dryer Repair 0 10-06-2007 09:41 AM
Dryer finishes cycle but clothers damp - Test moisture sensor ? rkpatt Dryer Repair 5 09-17-2007 09:08 AM
Moisture Sensor wire dwiley824 Dryer Repair 1 09-09-2007 08:21 PM
moisture sensors autoxracer Dryer Repair 3 09-04-2007 08:04 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
