Discuss
bad smell and mold growing in dishwasher
 in
Dishwasher Repair
we run our dishwasher at least once a day...we are growing mold on the inside drain and on other
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » bad smell and mold growing in dishwasher
  #1 (permalink)
Old 12-12-2007, 07:54 PM
kimc kimc is offline
Junior Member
kimc is on a distinguished road
Question bad smell and mold growing in dishwasher
Model Number: SHU43C   Brand: Bosch   Age: 1 - 5 years
we run our dishwasher at least once a day...we are growing mold on the inside drain and on other parts inside the machine... we clean it throughly and slowly the smell starts again and then the mold. There is no food that is visible in the drain catcher...could it be from a poorly working drain...I see standing water when I left the drain strainer...Any help would be great...nothing in the manual....
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-12-2007, 08:03 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
How is the drain hose connected to the garb. disp?
Does it have an air gap on top of the sink?
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 12-13-2007, 09:19 PM
kawfeeman kawfeeman is offline
Senior Expert
APP Volunteer
kawfeeman is on a distinguished road
Default
see if you can determine whether you have soft or hard water... sometimes it might be as simple as NOT pre-rinsing your dishes ( utilize the RINSE / HOLD program properly ) and only using suggested doseage of POWDERED detergent... ( may have too high a concentration of soap / detergent ) .. run d/w with no dishes etc and no detergent on economy for 9 minutes or more and then open door .. check if you have suds or not ... If so, reduce detergent doseage.. also, check wasteline to make sure it is draining well .. remove drain hose from disposal / sink tail piece and have d/w drain into a bucket.. you'll see a strong "stream" or flow of water... if it "dribbles" out , that is certainly a problem...
  #4 (permalink)
Old 01-05-2008, 05:25 AM
Junior Member
Default No Garbage dispos.
We don't have a garbage dispos. ...the water is fairly soft and the machine runs at least once or twice a day...several of our sinks seem to be draining slow...we are on a septic system...could there be any connection...
  #5 (permalink)
Old 01-05-2008, 05:29 AM
Junior Member
Default
I have only been using the gel detergent...why might powder help...We will check out the hose for proper draining...
  #6 (permalink)
Old 01-05-2008, 09:20 AM
Senior Expert
APP Volunteer
Default
european d/w's use much less water than typical domestic d/w's ... you need to adjust detergent to soil level and water hardness... typically 15ml of detergent ( 1 tblspn ) is more than enough powdered detergent for most BOSCH d/w loads ( need to saturate water with detergent, not super-saturate.. ) The gel packets are too much detergent for European d/w's... Also, NO pre-rinsing of dishes and no "cleaning" of sponges in the d/w... ( the d/w has a Rinse/Hold cycle to prevent food stuffs from sticking to your dishes and silverware. ) All of these tips can be confirmed by calling BOSCH directly ... you may want to test the hardness of your water if you have well water, if you have "city" water, your water hardness is controlled by your local. Try two 8 oz glasses of water.. leave both of them out, one with a splash of liquid soap and the other w/o remember to mix well.. ( But you must leave them in a dark , closed enviornment ).. the soapy one will get musty and moldy before the other ... make sure you are using your liquid rinse agent and rinse agent dispenser should be set between 2 &3 ...
__________________
regards
jim
  #7 (permalink)
Old 01-08-2008, 01:01 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Make sure there is a high loop in the drain hose at least 20" above the floor.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Mold Smell randy35 Washer Repair 1 04-11-2008 07:51 AM
Spent Gas Smell iatia Microwave Repair 2 12-11-2007 10:45 AM
mold in sump John Bates Dishwasher Repair 0 12-08-2007 07:05 AM
gas smell only when oven is on stevencsmith Oven Repair (including Ranges and Cooktops) 1 12-04-2007 12:23 AM
musty smell rbird528 Dryer Repair 1 10-06-2007 04:44 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
