I Tore It Down To The Impeller And All Looked Ok , I Found What Looked Like A Couple Of Small Pieces Of Stone , Thought That May Be The Problem , Reassembled , Still Not Draining . I Put A Shop Vac On The Drain Hose , And I Think It Is Clear. Wondering If There Is A Cam In The Control Switch That Could Be Messed Up , Not Giving The Drain Command ???
