Papalyons
Dishwasher will not run except when pushing cancel/drain. It then runs, but does not drain. Pushing any other cycle button, the lights light, but nothing happens. It filled with water when the cancel/drain was pressed
Remove the bottom access panel and check if the motor runs while the control calls for wash or drain.
Post the results. Gene. |
| All times are GMT -7. The time now is 12:55 AM. |
