| » water is not comming in |
Model Number: gsd2230z04w Brand: GE Age: 5 - 10 years
The cycle completes without problem but without water.
I replaced the valve water a month ago because of the same problem and now it is back. I'm wondering that maybe is not the value itself but something I touched when I was fixing it. Any clue on this? Related Models |
ren
Inside the dishwasher on the left side close to the front you can see the float dome (# 302 on the dishwasher body break down diagram ) and the float ( # 305 on the same diagram ). I believe it got stuck with a grease and old soap. Normally the float should easy go up and down. Also check the switch under the float ( #490 on the same diagram ). If this switch is open the power does not go to the water valve. Good luck. Gene. |
| Display Modes | |
