Discuss
Lower arm spray support (hub) broken
 in
Dishwasher Repair
My mom was pulling the lower rack out and the lower spray arm was probably up. I think she forced
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Lower arm spray support (hub) broken
  #1 (permalink)
Old 12-10-2007, 12:06 PM
gabhroo gabhroo is offline
Junior Member
gabhroo is on a distinguished road
Default Lower arm spray support (hub) broken
Model Number: GSD400W-56AD   Brand: GE   Age: More than 10 years
My mom was pulling the lower rack out and the lower spray arm was probably up. I think she forced it, and the arm support (hub) broke off. I found out the part number from your website (part 552 - AP2039804). However, I just want to make sure it is the exact piece.
Since only a small portion broke out, the rest of the portion is still in there, and I can't find a way to take it out. I have tried twisting it, or just pulling it out, but it doesn't budge at all.
Can you help me in taking it out?
I have attached the pictures of the broken part.
Thanks!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-10-2007, 12:21 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
In order to remove the hub you have to remove the pump (under the dishwasher) first.
The part number for the hub is the right one.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 12-10-2007, 12:38 PM
Junior Member
Default
Can you point me to some documentation/diagram as to how do I remove the pump (under the dishwasher)?
Thanks.
  #4 (permalink)
Old 12-10-2007, 12:50 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The first thing you have to do is to remove the dishwasher from the cabinet. Lay it down on the back to get access to the pump & motor assembly (#423 on the break down diagram).
Remove the pump & motor assembly and then remove the spray arm tube (#455) and the old hub.
__________________
  #5 (permalink)
Old 12-10-2007, 01:19 PM
Junior Member
Default
Before I take out the dishwasher, do I need to take out all the water supplies as well? The valve going from under the sink to dishwasher does not rotate at all (probably because it has never been closed).
  #6 (permalink)
Old 12-10-2007, 01:36 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Yes, you have to turn water supply off and disconnect the water line from the dishwasher. If the water shut off valve under the sink is frozen up, call a plumber to fix it first. You have to remove the power from the dishwasher too.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Lower Spray Arm Removal Chuckjacobs123 Dishwasher Repair 5 11-26-2007 12:15 PM
Lower arm wont spray irish332 Dishwasher Repair 1 11-14-2007 11:07 AM
reattach rear drum support pannel dmcglynn Dryer Repair 0 10-22-2007 11:20 AM
replacing lower spray arm bobmichael Dishwasher Repair 5 10-02-2007 03:27 AM
lower spray arm jiml Dishwasher Repair 1 09-10-2007 09:38 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
