Discuss
Maytag dishwasher won't cycle
 in
Dishwasher Repair
The machine will fill and stop. The timer will cycle through to the end, but there is no function, no
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Maytag dishwasher won't cycle
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-09-2007, 11:59 AM
anotherproject anotherproject is offline
Junior Member
anotherproject is on a distinguished road
Default Maytag dishwasher won't cycle
Model Number: MDB7100AWW   Brand: Maytag   Age: 5 - 10 years
The machine will fill and stop. The timer will cycle through to the end, but there is no function, no motor noise, etc.
There is just a tick tock clicking noise in the door panel every couple minutes.
At the end the CLEAN and Keypad 2 lights will blink steadily.
The wiring harness in the door was recently replaced by Maytag under a recall.
When I try the DRAIN/Off button the display shows cycle time and I can hear a relay clicking on the circuitboard in the door controls, but the pump motor does not come on.
I suspect maybe a failed relay on the circuit board or failed motor. There is some (heat) discoloration near two resistors on the cicuit board.
The motor armature spins easily (not jammed).
Any ideas?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-10-2007, 12:03 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Remove the bottom panel and check if the power is coming to the motor.
If there is power then replace the pump & motor assembly.
If there is no power then the control board has to be replaced.
- The part number for the control board AP3158621
To find the right part number for the pump & motor assembly I need you to post the serial number of the dishwasher.
- Here are the break down diagrams for the Maytag dishwasher Model MDB7100AWW
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 12-11-2007, 06:56 PM
Junior Member
Default
Thanks for your prompt reply, Gene.
If I unplug the lead to the motor and check there?
If I read the diagram correctly....
At the start of the cycle, after fill, I should expect power across BU and GY leads?(WASH)
S/N is 15899926yu
  #4 (permalink)
Old 12-11-2007, 07:12 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You can do the motor continuity test. From BU to all others suppose to be some resistance. If any of the motor winding is open - the motor is bad.
The power should come to the main winding as well as to the wash (BU & GY and BU & Y).
- The part number for the pump & motor assembly AP403850
__________________
  #5 (permalink)
Old 12-12-2007, 07:49 PM
Junior Member
Default
Thank you, Gene.
You were absolutely correct!
No power at the motor plug-at either winding.
So, I went to the board. Figured I had nothing to lose, so I removed the cover of the power relay.
The points supports had warped enough that the contacts couldn't close.
I just bent the support a little, and voila!
No more dishpan hands!
Thanks again! I will keep you in mind when it really croaks.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag dishwasher won't cycle anotherproject Dishwasher Repair 0 12-09-2007 11:56 AM
malfunctions in maytag cycle geoman Dryer Repair 1 12-07-2007 08:05 AM
Dishwasher skips the wash cycle and stops at the rinse cycle jasporo Dishwasher Repair 1 11-16-2007 05:12 PM
MAytag washer cycle ronald nicholls Washer Repair 1 11-12-2007 07:39 PM
Maytag dishwasher stuck on drain cycle ak47jazzfan Dishwasher Repair 3 10-15-2007 10:35 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
