joechausse
#1 Posted : Tuesday, May 5, 2009 4:13:49 AM(UTC)
joechausse
I was getting a high pitched sound coming during the fill cycle and the upper dishes were not being cleaned. I have replaced the inlet solenoid and the sound has gone but the upper rack dishes are still not getting cleaned. I have disassembled the tubes leading to the arm and they are not blocked. I know the lower are is spraying water and the upper arm and impeller are not. What would be causing this problem?
tdma
#2 Posted : Tuesday, May 5, 2009 7:02:39 AM(UTC)
tdma
The chopper blade could be broke. This causes the screen to clog and no water to the upper tray.
Place a glass right side up in the upper tray and it should fill with water if you are getting water to the top.
Easy enough to check.
joechausse
#3 Posted : Tuesday, May 5, 2009 7:05:29 AM(UTC)
joechausse
Thanks, already done and no water. I will check the chopper blade and screen.
