Discuss
detergent dispencer door won't lock shut on whirlpool gold dishwasher
 in
Dishwasher Repair
the detergent door will not lock closed can this be replaced or repaired by owner? It is the Gold model.
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » detergent dispencer door won't lock shut on whirlpool gold dishwasher
  #1 (permalink)
Old 05-02-2009, 10:18 AM
Junior Member
hsellman is on a distinguished road
Default detergent dispencer door won't lock shut on whirlpool gold dishwasher
Brand: Whirlpool   Age: 1 - 5 years
the detergent door will not lock closed can this be replaced or repaired by owner? It is the Gold model. number above ser # is fr07018275 serial gu1500xtls3. purchased april 2004
  #2 (permalink)
Old 05-05-2009, 03:27 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Replacement parts for WHIRLPOOL GU1500XTLS3 | AppliancePartsPros.com
Here is the tech sheet
https://www.servicematters.com/docs/...%208537797.pdf
And a service manual
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/52521bdbd0ef763c85256cbc00520548/$FILE/8178022.pdf
Problem can be due to 3 causes:
1. Mechanical
2. Dispenser assembly solenoid/motor is shot
3. Dispenser is not receiving power from the control when it should.
Remove the inner door panel and check the detergent assembly for a visual mechanical fault. Also check the wires going to the solenoid/motor on the dispenser.
Check the release motor resistance, see the tech sheet, if open (infinite resistance), the dispenser will have to be replaced.
Run the diagnostics.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
detergent door does not lock clglenn Dishwasher Repair 0 10-17-2009 10:12 AM
dishwasher detergent door llewand Dishwasher Repair 1 09-28-2009 05:17 AM
Whirlpool duet door will not shut and lock bobo796 Washer Repair 2 01-15-2009 10:38 AM
Whirlpool Gold Detergent Cup switch constantly open RyanLeah Dishwasher Repair 1 01-02-2009 06:23 PM
Whirlpool Gold Dishwasher Detergent Latch Rob12345 Dishwasher Repair 1 03-16-2008 06:28 PM
