Discuss
kenmore DW pumps out in wash cycle
 in
Dishwasher Repair
I have a client whose kenmore DW pumps out while in wash cycle-what do you think?
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » kenmore DW pumps out in wash cycle
  #1 (permalink)
Old 10-12-2011, 08:06 PM
Junior Member
paul martin is on a distinguished road
Angry kenmore DW pumps out in wash cycle
Brand: Kenmore   Age: 5 - 10 years
  #2 (permalink)
Old 10-13-2011, 05:39 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
A model number may help others help you.
Did the unit used to run OK? If not it could be the drain is not looped higher than where it enters the house plumbing or perhaps it has come loose and fallen.
If the unit has a separate drain pump you will have to find out if that pump is running when it should not be.
The unit may also have a check valve or flapper valve that is not closing properly.
__________________
  #3 (permalink)
Old 10-13-2011, 07:14 AM
Junior Member
Default
The unit ran correctly one minute and next it didn't.
All plumbing intact and check valve clear-no obstruction.
No separate drain pump in system.No energized drain valve in system.
Does this motor reverse in order to drain.
Thanks denman for your ideas-Paul
  #4 (permalink)
Old 10-13-2011, 08:02 AM
Senior Expert
APP Volunteer
Default
Still need a model number.
Kenmore does not make anything so it could be anyone's unit.
Model Number Locator
__________________
  #5 (permalink)
Old 10-13-2011, 08:44 AM
Junior Member
Default
I'll be back w/model# etc. shortly
thanks denman-paul
  #6 (permalink)
Old 10-13-2011, 10:34 AM
Junior Member
Default
denman or others-
kenmore m#-665.17425792
when dw in wash mode lead from relay shows 118v to N,wash lead from timer shows 45v to N,drain lead from timer shows 45v to N.It pumps out during both wash & drain modes.
thx-paul
  #7 (permalink)
Old 10-13-2011, 02:14 PM
Senior Expert
APP Volunteer
Default
Here are the parts
Replacement parts for KENMORE 66517425792 | AppliancePartsPros.com
The Sears parts site will have parts breakdowns.
Here is a manual. I am not sure if it is an exact match but looking at the pump it should be close.
http://appliancedigest.com/index.php...service-manual
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
I would start with the soil separator it is a common problem.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Unit pumps the water out in wash cycle? rifraf2001 Dishwasher Repair 2 10-12-2011 09:31 PM
Kenmore Ultra Wash stops mid cycle sb.dustin Dishwasher Repair 0 06-28-2011 02:10 PM
kenmore ultra wash 665.16354300 Very noisy during wash cycle hogues Dishwasher Repair 1 03-07-2010 02:47 PM
Kenmore Spins In Wash Cycle wasjunk Washer Repair 0 01-21-2010 08:16 PM
Washer pumps in aggitate cycle spencer1989 Washer Repair 8 10-09-2009 05:05 AM
