| » Removing the spin shaft flange |
Model Number: PAV2200AWW Brand: Maytag Age: 1 - 5 years
I am working on a Maytag Washing Machine that makes a loud roaring sound when it goes into the spin cycle-so loud you don't want to be in the same room with it.
I have removed the wash tub and the plastic nut on the spin cycle shaft but below the nut is a 4 bolt flange that I need to remove. It is aluminum and I have been to the web site and the on line help but can not tell if it is threaded or or if I need to use a puller on it. Thanks J Ads By Google Related Models |
Hopefully the Service manual will help. Possible you'll need some special tools.
Here are the breakdown diagrams and Replacement parts for MAYTAG PAV2200AWW | AppliancePartsPros.com Gene. P.S. Check how freely the pump pulley is moving. It can be noisy too.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
As it turns out-the spin hub is threaded and the hub may require a bit of coaxing with a rubber mallet and a large wrench. I also had to clamp the agitator shaft to keep it from turning while I rapped on the hub wrench.
Once I had it unscrewed and the tub removed I found that the hub seal had deteriorated and water had rusted the spin bearing--lots of noise. A new part from this site and all fixed. Thanks for the help Gene. |
You are welcome. I'm glad you were able to fix it.
__________________
| Display Modes | |
| Removing yoke from auger moter shaft | bigart99 | Refrigerator & Freezer Repair | 2 | 12-29-2010 05:30 AM |
| kenmore 70 series washer will not agitate/spin + rusty drive shaft/pump | pkme | Washer Repair | 2 | 01-27-2009 07:55 AM |
| removing metal sleeve from shaft | zaxxon | Washer Repair | 2 | 12-03-2008 05:23 AM |
| Flange snap ring not holding, specialty flange | wranglerbrat | Garbage Disposer Repair | 0 | 11-27-2008 10:57 AM |
| Replace disposal flange | redfox | Garbage Disposer Repair | 2 | 03-30-2008 01:22 PM |
