Discuss
high pitched squel
 in
Dishwasher Repair
I have an lg dishwasher that developed a high pitched squel when operating- sometimes in wash sometimes thru many cycles-
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » high pitched squel
  #1 (permalink)
Old 10-06-2011, 06:52 PM
Junior Member
arczele is on a distinguished road
Question high pitched squel
Model Number: LDF8812st   Brand: -other-   Age: 1 - 5 years
I have an lg dishwasher that developed a high pitched squel when operating- sometimes in wash sometimes thru many cycles- they have replaced the circulator motor on the bottom and then the vapor assmby motor in the door panel- still a high pitched noise- not a water inlet noise - more like a bad bearing or metal to metal that varies pitch- I noticed in your parts fiche that there is another pump assembly on the side by the main motor- does this motor run all the time- the noise can run for 20-30 minutes
Ads By Google
Related Models
 LDF8812ST Dishwasher
 LDF9810ST Dishwasher
 LDF9932ST Dishwasher
Admiral LDG1000AAE DRYER- GAS
Maytag LDG110 DRYER- GAS
Maytag LDG18CA MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG18CM MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG18CS MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG18CT MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG19CD MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG19CS MANUAL, PARTS (DRYER GAS)
Maytag LDG19CT MANUAL, PARTS (DRYER GAS)
Maytag LDG210 DRYER- GAS
Maytag LDG212 DRYER- GAS
Maytag LDG21CS MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG22CS MANUAL, PARTS (DRYER GAS)
Maytag LDG22CT MANUAL, PARTS (DRYER GAS)
Maytag LDG23CD MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG24CA MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG24CM MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG24CS MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG24CT MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG25CS MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG26CA MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag LDG26CD MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag LDG26CS MANUAL, PARTS (DRYER GAS)
Maytag LDG26CT MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag LDG27CA MANUAL, PARTS (DRYER GAS)
Maytag LDG27CD MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag LDG27CS MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG27CT MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG303 DRYER- GAS
Maytag LDG30CMD MANUAL, PARTS (DRYER GAS)
Maytag LDG312 DRYER- GAS
Maytag LDG313 DRYER- GAS
Maytag LDG31CA MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG31CM MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG31CT MAYTAG LAUNDRY (DRYER GAS)
Frigidaire LDG333PEW0 Frg(v0) / Gas Dryer
Maytag LDG33CA MANUAL, PARTS (DRYER GAS)
Maytag LDG33CM MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG34CD MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG34CQ MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG382 DRYER- GAS
Maytag LDG4000 DRYER- GAS
Maytag LDG4000AAL DRYER- GAS
Maytag LDG4000AAW DRYER- GAS
Maytag LDG4000ABL DRYER- GAS
Maytag LDG4000ABW DRYER- GAS
Maytag LDG410 DRYER- GAS
Maytag LDG412 DRYER- GAS
Maytag LDG482 DRYER- GAS
Maytag LDG490 DRYER- GAS
Maytag LDG4910 DRYER- GAS
Maytag LDG4910AAL DRYER- GAS
Maytag LDG4910AAW DRYER- GAS
Maytag LDG4914AAE DRYER- GAS
Maytag LDG4914AAL DRYER- GAS
Maytag LDG4914AAM DRYER- GAS
Maytag LDG4916AAE DRYER- GAS
Maytag LDG4916AAM DRYER- GAS
Maytag LDG5004AAW DRYER- GAS
Maytag LDG5004ABW DRYER- GAS
Maytag LDG5005AAE DRYER- GAS
Maytag LDG5005ABE DRYER- GAS
Maytag LDG510 DRYER- GAS
Maytag LDG512 DRYER- GAS
Maytag LDG590 DRYER- GAS
Maytag LDG5910 DRYER- GAS
Maytag LDG5910AAL DRYER- GAS
Maytag LDG5910AAW DRYER- GAS
Maytag LDG5914AAE DRYER- GAS
Maytag LDG5914AAL DRYER- GAS
Maytag LDG5914AAM DRYER- GAS
Maytag LDG5916AAE DRYER- GAS
Maytag LDG5916AAM DRYER- GAS
Maytag LDG6004AAW DRYER- GAS
Maytag LDG610 DRYER- GAS
Maytag LDG612 DRYER- GAS
Maytag LDG6914AAE DRYER- GAS
Maytag LDG6914AAL DRYER- GAS
Maytag LDG6914AAM DRYER- GAS
Maytag LDG710 DRYER- GAS
Maytag LDG712 DRYER- GAS
Maytag LDG713 DRYER- GAS
Maytag LDG7304AAE DRYER- GAS
Maytag LDG7304AAL DRYER- GAS
Maytag LDG7304AAM DRYER- GAS
Maytag LDG7304ABE DRYER- GAS
Maytag LDG7304ABL DRYER- GAS
Maytag LDG7304ABM DRYER- GAS
Maytag LDG7304AGE DRYER- GAS
Maytag LDG7304AGL DRYER- GAS
Maytag LDG7304AGM DRYER- GAS
Maytag LDG7304EGE DRYER- GAS
Maytag LDG7304EGL DRYER- GAS
Maytag LDG7304EGM DRYER- GAS
Maytag LDG7314AAE DRYER- GAS
Maytag LDG7314AAL DRYER- GAS
Maytag LDG7314AAM DRYER- GAS
Maytag LDG7334AAE DRYER- GAS
Maytag LDG7334AAL DRYER- GAS
Maytag LDG7334AAM DRYER- GAS
Maytag LDG7400 DRYER- GAS
Maytag LDG7400AAL DRYER- GAS
Maytag LDG7400AAW DRYER- GAS
Maytag LDG7400ABL DRYER- GAS
Maytag LDG7400ABW DRYER- GAS
Maytag LDG7480AAL DRYER- GAS
Maytag LDG7480AAW DRYER- GAS
Maytag LDG7480ABL DRYER- GAS
Maytag LDG7480ABW DRYER- GAS
Maytag LDG7500 DRYER- GAS
Maytag LDG7500AAE DRYER- GAS
Maytag LDG7500AAL DRYER- GAS
Maytag LDG7500AAM DRYER- GAS
Maytag LDG7500AAW DRYER- GAS
Maytag LDG7500ABE DRYER- GAS
Maytag LDG7500ABL DRYER- GAS
Maytag LDG7500ABM DRYER- GAS
  #2 (permalink)
Old 10-08-2012, 05:42 PM
Junior Member
jammaker is on a distinguished road
Default
Mine did the same. Talked to a technician and he said it is a very common problem. From inside the dishwasher at the bottom take parts off to expose pump. There is a metal blade that can be turned upside down and it will stop for awhile. After that the pump needs to be replaced.
  #3 (permalink)
Old 10-09-2012, 01:24 PM
Junior Member
Katzelff is on a distinguished road
Default
It's the motor. Big problem with lg
  #4 (permalink)
Old 10-09-2012, 04:04 PM
Junior Member
Default
I would try the cutting blade first. LG came out with a new part number that supersedes the old cutting blade. The new part # is [FONT='Calibri','sans-serif']5832DD4001B and can be ordered here. Blade is less than $5 and took care of my high shrill squell. [/font]
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer high pitched noise DEG 3 Dryer Repair 0 10-22-2009 02:59 PM
High pitched squeak rcakelady Dryer Repair 1 09-21-2009 04:35 AM
dryer -high pitched noise mscerbak Dryer Repair 1 01-21-2009 05:26 AM
High pitched squealing noise b428337 Dryer Repair 3 10-06-2008 02:41 PM
high pitched noise Raleigh Dishwasher Repair 1 12-20-2007 06:35 AM
