Appliance Repair Forum
-   Dishwasher Repair (http://forum.appliancepartspros.com/dishwasher-repair/)
-   -   high pitched squel (http://forum.appliancepartspros.com/dishwasher-repair/318842-high-pitched-squel.html)
arczele 10-06-2011 06:52 PM
high pitched squel
I have an lg dishwasher that developed a high pitched squel when operating- sometimes in wash sometimes thru many cycles- they have replaced the circulator motor on the bottom and then the vapor assmby motor in the door panel- still a high pitched noise- not a water inlet noise - more like a bad bearing or metal to metal that varies pitch- I noticed in your parts fiche that there is another pump assembly on the side by the main motor- does this motor run all the time- the noise can run for 20-30 minutes
jammaker 10-08-2012 05:42 PM
Mine did the same. Talked to a technician and he said it is a very common problem. From inside the dishwasher at the bottom take parts off to expose pump. There is a metal blade that can be turned upside down and it will stop for awhile. After that the pump needs to be replaced.
Katzelff 10-09-2012 01:24 PM
It's the motor. Big problem with lg
jammaker 10-09-2012 04:04 PM
I would try the cutting blade first. LG came out with a new part number that supersedes the old cutting blade. The new part # is [FONT='Calibri','sans-serif']5832DD4001B and can be ordered here. Blade is less than $5 and took care of my high shrill squell. [/font]
