Discuss
Top Rack Not Clean / Not Enough Water?
 in
Dishwasher Repair
Hi all, Last week, I noticed the dishes were not cleaning as they should. We have moderately hard water, so
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Top Rack Not Clean / Not Enough Water?
  #1 (permalink)
Old 10-04-2011, 11:03 PM
Junior Member
muzicman82 is on a distinguished road
Default Top Rack Not Clean / Not Enough Water?
Model Number: GU2400XPTB3   Brand: Whirlpool   Age: 1 - 5 years
Hi all,
Last week, I noticed the dishes were not cleaning as they should. We have moderately hard water, so I knew right off the bat what the problem was - rust build up in the inlet valve screen. It happens on all of our appliances. On the last dishwasher, I had to clean out the rust every couple months. On this one, I haven't had to do it really since we got it 5 years ago. Amazing.
So, I took out the inlet valve and disassembled it COMPLETELY. I took a toothbrush with Iron Out and even sandpaper to it. When it went back together, you wouldn't be able to tell if it was old or new. I'm confident that it is back together properly.
After that, I ran a cycle and noticed that dishes were much cleaner, but still not right. So I took out the lower wash arm and components, only to find the food chopper shaft had broken, so the screen was all clogged up. I figured, well great, at least I found the problem.
So I ordered a food chopper and put that in today. Ran a cycle and the top rack was indeed cleaner than it was previously. Then I ran a full load and the top rack is surely not cleaning properly.
Anyone have any other ideas?
I have two:
  • The water inlet valve solenoid is bad, so I should replace the valve anyway.
  • The float is defective.
I think the bottom line is that enough water is not entering the tank. When I start the dishwasher, I can hear water enter, but it seems like it is trickling out of the port. Is there any way to tell if it is filling with enough water?
I imagine that without enough water, the pump doesn't send enough water to the upper rack arm, and so it doesn't spin.
Does anyone think I should replace the water inlet valve, the sump check valve, or anything else? What is the water inlet assembly? I know the valve sends water there, but is there anything that can become clogged on that part? I assume I have to take the dishwater out to get to it?
Ideas would be great!
Ads By Google
Related Models
Whirlpool GU2400XTPB0 Undercounter Dishwasher
Whirlpool GU2400XTPB1 Dishwasher
Whirlpool GU2400XTPB3 Undercounter Dishwasher
Whirlpool GU2400XTPB6 Dishwasher
Whirlpool GU2400XTPB7 Undercounter Dishwasher
Whirlpool GU2400XTPQ0 Undercounter Dishwasher
Whirlpool GU2400XTPQ1 Undercounter Dishwasher
Whirlpool GU2400XTPQ3 Undercounter Dishwasher
Whirlpool GU2400XTPQ6 Undercounter Dishwasher
Whirlpool GU2400XTPQ7 Undercounter Dishwasher
Whirlpool GU2400XTPS0 Undercounter Dishwasher
Whirlpool GU2400XTPS1 Undercounter Dishwasher
Whirlpool GU2400XTPS3 Undercounter Dishwasher
Whirlpool GU2400XTPS6 Undercounter Dishwasher
Whirlpool GU2400XTPS7 Undercounter Dishwasher
Whirlpool GU2400XTPT0 Undercounter Dishwasher
Whirlpool GU2400XTPT1 Dishwasher
Whirlpool GU2400XTPT3 Undercounter Dishwasher
Whirlpool GU2400XTPT6 Dishwasher
Whirlpool GU2400XTPT7 Undercounter Dishwasher
Whirlpool GU2451XTSB0 Undercounter Dishwasher
Whirlpool GU2451XTSB1 Undercounter Dishwasher
Whirlpool GU2451XTSB2 Undercounter Dishwasher
Whirlpool GU2451XTSQ0 Undercounter Dishwasher
Whirlpool GU2451XTSQ1 Undercounter Dishwasher
Whirlpool GU2451XTSQ2 Undercounter Dishwasher
Whirlpool GU2451XTSS0 Undercounter Dishwasher
Whirlpool GU2451XTSS1 Undercounter Dishwasher
Whirlpool GU2451XTSS2 Undercounter Dishwasher
Whirlpool GU2451XTST0 Undercounter Dishwasher
Whirlpool GU2451XTST1 Undercounter Dishwasher
Whirlpool GU2451XTST2 Undercounter Dishwasher
Whirlpool GU2455XTSB0 Undercounter Dishwasher
Whirlpool GU2455XTSB1 Undercounter Dishwasher
Whirlpool GU2455XTSB2 Undercounter Dishwasher
Whirlpool GU2455XTSB3 Undercounter Dishwasher
Whirlpool GU2455XTSQ0 Undercounter Dishwasher
Whirlpool GU2455XTSQ1 Undercounter Dishwasher
Whirlpool GU2455XTSQ2 Undercounter Dishwasher
Whirlpool GU2455XTSQ3 Undercounter Dishwasher
Whirlpool GU2455XTSS0 Undercounter Dishwasher
Whirlpool GU2455XTSS1 Undercounter Dishwasher
Whirlpool GU2455XTSS2 Undercounter Dishwasher
Whirlpool GU2455XTSS3 Undercounter Dishwasher
Whirlpool GU2455XTST0 Undercounter Dishwasher
Whirlpool GU2455XTST1 Undercounter Dishwasher
Whirlpool GU2455XTST2 Undercounter Dishwasher
Whirlpool GU2455XTST3 Undercounter Dishwasher
Whirlpool GU2500XTPB0 Undercounter Dishwasher
Whirlpool GU2500XTPB1 Undercounter Dishwasher
Whirlpool GU2500XTPB3 Undercounter Dishwasher
Whirlpool GU2500XTPB6 Undercounter Dishwasher
Whirlpool GU2500XTPB7 Undercounter Dishwasher
Whirlpool GU2500XTPQ0 Undercounter Dishwasher
Whirlpool GU2500XTPQ1 Undercounter Dishwasher
Whirlpool GU2500XTPQ3 Undercounter Dishwasher
Whirlpool GU2500XTPQ6 Undercounter Dishwasher
Whirlpool GU2500XTPQ7 Undercounter Dishwasher
Whirlpool GU2500XTPS0 Undercounter Dishwasher
Whirlpool GU2500XTPS1 Undercounter Dishwasher
Whirlpool GU2500XTPS3 Undercounter Dishwasher
Whirlpool GU2500XTPS6 Undercounter Dishwasher
Whirlpool GU2500XTPS7 Undercounter Dishwasher
Whirlpool GU2500XTPT0 Undercounter Dishwasher
Whirlpool GU2500XTPT1 Undercounter Dishwasher
Whirlpool GU2500XTPT3 Undercounter Dishwasher
Whirlpool GU2500XTPT6 Undercounter Dishwasher
Whirlpool GU2500XTPT7 Undercounter Dishwasher
Whirlpool GU2548XTPB0 Undercounter Dishwasher
Whirlpool GU2548XTPQ0 Undercounter Dishwasher
Whirlpool GU2548XTPQ1 Undercounter Dishwasher
Whirlpool GU2548XTPQ3 Undercounter Dishwasher
Whirlpool GU2548XTPQ6 Undercounter Dishwasher
Whirlpool GU2548XTPQ7 Undercounter Dishwasher
Whirlpool GU2548XTPS0 Undercounter Dishwasher
Whirlpool GU2548XTPS1 Undercounter Dishwasher
Whirlpool GU2548XTPS3 Undercounter Dishwasher
Whirlpool GU2548XTPS6 Undercounter Dishwasher
Whirlpool GU2548XTPS7 Undercounter Dishwasher
Whirlpool GU2548XTPT0 Undercounter Dishwasher
Whirlpool GU2600XTPB0 Undercounter Dishwasher
Whirlpool GU2600XTPB1 Undercounter Dishwasher
Whirlpool GU2600XTPB3 Undercounter Dishwasher
Whirlpool GU2600XTPB6 Undercounter Dishwasher
Whirlpool GU2600XTPB7 Undercounter Dishwasher
Whirlpool GU2600XTPQ0 Undercounter Dishwasher
Whirlpool GU2600XTPQ1 Undercounter Dishwasher
Whirlpool GU2600XTPQ3 Undercounter Dishwasher
Whirlpool GU2600XTPQ6 Undercounter Dishwasher
Whirlpool GU2600XTPQ7 Undercounter Dishwasher
Whirlpool GU2600XTPS0 Undercounter Dishwasher
Whirlpool GU2600XTPS1 Undercounter Dishwasher
Whirlpool GU2600XTPS3 Undercounter Dishwasher
Whirlpool GU2600XTPS6 Undercounter Dishwasher
Whirlpool GU2600XTPS7 Undercounter Dishwasher
Whirlpool GU2600XTPT0 Undercounter Dishwasher
Whirlpool GU2600XTPT1 Undercounter Dishwasher
Whirlpool GU2600XTPT3 Undercounter Dishwasher
Whirlpool GU2600XTPT6 Undercounter Dishwasher
Whirlpool GU2600XTPT7 Undercounter Dishwasher
Whirlpool GU2700XTSB0 Undercounter Dishwasher
Whirlpool GU2700XTSB1 Undercounter Dishwasher
Whirlpool GU2700XTSQ0 Undercounter Dishwasher
Whirlpool GU2700XTSQ1 Undercounter Dishwasher
Whirlpool GU2700XTSS0 Undercounter Dishwasher
Whirlpool GU2700XTSS1 Undercounter Dishwasher
Whirlpool GU2700XTST0 Undercounter Dishwasher
Whirlpool GU2700XTST1 Undercounter Dishwasher
Whirlpool GU2700XTSY0 Undercounter Dishwasher
Whirlpool GU2700XTSY1 Undercounter Dishwasher
Whirlpool GU3200XTPB0 Undercounter Dishwasher
Whirlpool GU3200XTPB1 Undercounter Dishwasher
Whirlpool GU3200XTPB3 Undercounter Dishwasher
Whirlpool GU3200XTPB4 Undercounter Dishwasher
Whirlpool GU3200XTPB5 Undercounter Dishwasher
Whirlpool GU3200XTPQ0 Undercounter Dishwasher
Whirlpool GU3200XTPQ1 Undercounter Dishwasher
Whirlpool GU3200XTPQ3 Undercounter Dishwasher
Whirlpool GU3200XTPQ4 Undercounter Dishwasher
Whirlpool GU3200XTPQ5 Undercounter Dishwasher
  #2 (permalink)
Old 10-05-2011, 06:43 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for GU2400XPTB3 models | AppliancePartsPros.com
The float is just an overfill protection so it should not be you problem.
You can check for a low fill by adding a couple quarts of hot water after each fill during a cycle. If it now runs OK I would replace the valve.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
top rack doesn't clean Novice Dishwasher Repair 0 10-16-2010 10:21 AM
top rack not getting clean jrunyans Dishwasher Repair 3 06-25-2010 05:45 PM
Top rack not getting clean,bottom rack clean lonwolfman Dishwasher Repair 0 01-18-2010 01:42 AM
Dishes on top rack not clean...... FDAR Dishwasher Repair 5 03-20-2009 01:39 AM
Top rack not clean boscoe Dishwasher Repair 3 08-14-2007 12:59 PM
