theschlepp
#1 Posted : Friday, September 30, 2011 5:25:59 AM(UTC)
theschlepp
A friend recommended this forum because the advice helped them. The great advice helped me when I first experienced a draining issue with my dishwasher.
When I first experienced drain issues I followed the instructions in this great post - http://forum.appliancepartspros.com/dishwasher-repair/16487-ge-profile-dishwasher-wont-drain-completely.html - but unfortunately it is not working this time.
I checked the sump then performed the reset test after letting the washer fill. The pump activates and water drains initially, but then you can hear a valve or something close and water stops draining. The timing of the valve closure varies from almost immediately to a few seconds. The pump continues to run for a minute or two.
I also went in to the service mode to isolate and activate the pump. Again, the pump activates and water drains initially, but then you can hear a valve or something close and water stops draining. The timing of the valve closure varies from almost immediate to a few seconds. The pump continues to run until I deactivate it. I used a shop-vac to remove the standing water. Shy of calling a repairman, I am out of ideas. Any advice, suggestions or recommendations is much appreciated. Thank you.
leewhite1
#2 Posted : Monday, October 3, 2011 6:03:12 AM(UTC)
leewhite1
I'm having same problem dishwasher won't drain. It's a GE Quietpower1. First it wouldn't go thur it's cycles, but now it is but it want drain.
Please Help
DCS (Fisher & Paykel) DD24DV2T7 Two Drawer Dishwasher Not Draining Fully (Dishwasher Repair)
by DCBUS 4/7/2023 5:44:37 AM(UTC)
Inglis dishwasher not draining - trouble removing filter (Dishwasher Repair)
by Guest 2/18/2023 5:24:29 AM(UTC)
Dishwasher not Draining - Frigidaire (Dishwasher Repair)
by Guest 12/10/2022 3:04:30 PM(UTC)
Whirlpool Dishwasher not draining at end of cycle-intermittently (Dishwasher Repair)
by Floyd Pinkerton 9/28/2022 11:07:32 AM(UTC)
Whirlpool dishwasher not draining with diagnostics code 6-4 (Dishwasher Repair)
by dcelbert 12/28/2021 11:04:45 AM(UTC)
GE Dishwasher not draining, no clogs anywhere (Dishwasher Repair)
by DanielWS 9/16/2020 11:32:15 AM(UTC)
Dishwasher not draining fully (Dishwasher Repair)
by ernestcmjr 1/29/2016 12:51:58 PM(UTC)
Kitchenaid dishwasher not draining... (Dishwasher Repair)
by mjl1297 1/19/2016 7:03:55 PM(UTC)
Whirlpool dishwasher not draining (model WDF730PAYB6) (Dishwasher Repair)
by patrick04 12/20/2015 7:40:06 PM(UTC)
Kitchen Aid Dishwasher Not Draining (Dishwasher Repair)
by jrdardano 7/18/2015 1:23:21 PM(UTC)
Dishwasher not draining after cycle (Dishwasher Repair)
by sanjayg1971 7/1/2015 10:37:25 AM(UTC)
Dishwasher not draining (Dishwasher Repair)
by CTLewis 2/23/2014 1:43:26 PM(UTC)
Amana dishwasher not draining completely (Dishwasher Repair)
by dennis728 11/24/2013 4:26:15 PM(UTC)
whirlpool dishwasher not draining (Dishwasher Repair)
by mdauer2002 5/28/2013 1:28:01 PM(UTC)
Dishwasher not draining, hoses/filter are clear (Dishwasher Repair)
by limon 3/1/2013 8:37:12 AM(UTC)
