| » Unit does not power up/run |
Replacement parts for WHIRLPOOL GU2500XTPS0 | AppliancePartsPros.com Here is the tech sheet https://www.servicematters.com/docs/...%208557727.pdf If you are sure it has power, then the first thing I would check would be the thermal fuse (Item 6 in the "Control parts" section). These seem to go on a regular basis hence they are now in a kit with the harness. Next would be the door switches.
__________________
Quote:
Where do you find the "Control parts" section? I've looked through the owner's use and care guide manual, is that a repair manual you've referenced? |
OOPS!!
Should have been "Control panel parts" Replacement parts for WHIRLPOOL GU2500XTPS0 | AppliancePartsPros.com
__________________
| Display Modes | |
| A/C window unit has power but no function | #1Travis | Heating, Ventilation, and Air Conditioning (HVAC) | 1 | 06-27-2010 03:38 PM |
| Nothing is running, but it has power to the unit | rmerath | Refrigerator & Freezer Repair | 0 | 09-18-2009 07:54 PM |
| Dryer does not turn has power to plug and unit | wxperez | Dryer Repair | 2 | 05-24-2009 08:09 AM |
| Maytag AC unit with no power | husbys@mninter.net | Heating, Ventilation, and Air Conditioning (HVAC) | 2 | 09-02-2008 08:17 AM |
| Power to unit: no run +water left in bottom | chandlers | Dishwasher Repair | 0 | 07-09-2008 08:08 PM |
